This is the actual mold lab results sent to me from a Realtor with all the identifying information removed.
Here is the back ground - This is a Florida mold remediation company who gave the client their post mold test results as a clearance report. Within a very short time I could tell it was doctored and not the "real" results. Can you count the number of discepencies and I did find out the guy used a PDF program to alter the report. Can you see it? No fault of Pro Lab at all...they sent the correct report as they received it. My report came back with 56,000 Pen/Asp spores and theirs was relatively clean...this is how all this came about. A lawyer called me in and I am sure it will go further. Just a little test and see if we agree on the items... ![]() ![]() ![]()
Comprehensive Building Consultants Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection. Donate here: or send checks to the Fl Home and Insurance Inspector Chapter 1103 W Hibiscus Blvd Ste 311 Melbourne, Fl 32901
| Need a home inspection in Ohio? Check out InterNACHI's listing of Ohio certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
no bites?
Jim,
I see incorrect dates; how can they report the results the day before they received the sample. Mark Raumikaitis, CMI, NH Lic #133 HomeCheck Professional Home Inspections LLC Derry, NH 603-432-3211 Inspecting New Hampshire and Southern Maine http://homecheckhomeinspections.com/ "Always think long term, do not be influenced by short term thinking or rewards."
No COC not worth anything!
THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
First, Z-25 are designed for preliminary testing only, per manufacturer
Also there is fiberglass in the control sample, which indicates the sample was taken too close to the building or down wind from a building. Also the controls would not be the same if taken on different days. Another thing, is the Asp/Pen is too high on the controls and should have been rejected for a clearance sample. 920 Asp/Pen is too high in the Guest Area on a clearance, no matter what the outside count was. Also I have a hard time believing there was only Asp/Pen in the Guest Area when the count was 920, because Asp/Pen has other molds that hang around it. I have never seen it as a loner, not at a high count anyway. The biggest mystery is Zygosporium. I have understood that under a microscope, nobody can tell what a Zygosporium spore is when collected with an air trap. Especially not under a 40 detection limit. The bad dating on the reports is comical. Also, Russ, do you have a lot of mushrooms (Ganoderma) outside in your area. I have only seen them on inside samples in Missouri and not very often. Braun Inspection Consultants Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
I do not think there is anything that requires a COC to be attached with a report. It is suppose to be asked for, later, if need be.
It is like attaching your training certificates, unless it is required by your state. Braun Inspection Consultants Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
Also, Russ, the IICRC S520, Second Edition requires involvement of an Indoor Environmental Professional to be involved in the process. This remediator should not have even started the job without one. Sounds like this remediator is toast.
James...your mold knowledge is AWESOME and thats why I recommended you to my girlfriends grandparents... Comprehensive Building Consultants Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection. Donate here: or send checks to the Fl Home and Insurance Inspector Chapter 1103 W Hibiscus Blvd Ste 311 Melbourne, Fl 32901
Florida law he it TOTALLY screwed....you cannot give a clearance test on your own job! Well you can...its just illegal...
I didn't even bother to blow it up after I saw no address and no 10 digit #
No info as to the Company ect. THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
| Home Inspectors and Mold | douglas | Florida Inspectors | 30 | 7/15/11 5:21 PM |
| Why the repeal move on mold law | douglas | Florida Inspectors | 26 | 3/17/11 8:48 PM |
| Dr. Shane says every home should be tested for mold. | gromicko | Ancillary Inspection Services & Additional Topics | 106 | 6/7/09 3:36 AM |
| Mold Testing Kansas City | dmoriconi | Ancillary Inspection Services & Additional Topics | 0 | 1/11/09 1:44 PM |
| Mold won't grow in Arizona,& other falsehoods | dplummer | Ancillary Inspection Services & Additional Topics | 4 | 1/22/08 5:41 AM |
