Old 3/9/06, 8:01 PM
Andy T. Bishop Andy T. Bishop is offline
Default Mold test results
I did my first mold test the other day and just got the results. I use pro-lab and used the swab and air-o-cells.
I called the lab and they said things were not good but what is good and bad results.
I had Stachybotrys at Raw count of 4 and Spores/M3 at 27.
I had Penicillium/Aspergillus at Raw 688 and Spores/M3 at 4587.
I had Cladosporium at Raw 12 and Spores 80.
I was not able to do an outside test or garage being there was no garage and it was like 20 degrees outside.
APPRECIATE ANY INSIGHT ON THIS.
Thanks
Old 3/9/06, 9:18 PM
Jay Schwartz's Avatar
Jay Schwartz Jay Schwartz is offline
Default Re: Mold test results
Without the outside control sample, your results cannot be validated.
There is no indication of stachy count on your report.
Jay Schwartz
Coast To Coast Home Services, Inc
Your Florida Home Inspection Company TM
Corporate Office: 954-673-3479
Naples Office: 239-298-4396
1-877-79-Windstorm
www.CoastToCoastHomeServices.com
www.SaveOnWindStorm.com
South Florida Home Inspectors Association
Southeast Florida NACHI Chapter - VP
Old 3/9/06, 9:53 PM
That was only one sample i attached. That was the worst Pen/Asp report of them all. The basement had no Stach, and the main floor and upstairs did.
I understand without outside control, it is tough. But the visual problem was down stairs, so i did one on each floor and that sucks.
Just was curious on what other counts people have had and how they compare?
Thanks
Old 3/9/06, 11:58 PM
rweiss rweiss is offline
I recently took a Mold certification class sponsored by NACHI & Pro-Lab. The class was taught by the Environmental Solutions Association. The class was excellent and well worth it.
According to ESA, if you have visible mold, the proper sampling protocol would be to take a swab sample, plus take interior and exterior air samples.
I recommend that you contact ESA at http://www.envirosolution.com/ for more info.
Old 3/10/06, 1:22 AM
gporter's Avatar
gporter gporter is offline
ESA is good.
Gary Porter
GLP's Home and Mold Inspections
321-239-0621
Certified Commercial Mold Inspector
Serving Orlando, Kissimmee, Winter Park, Winter Springs, Oviedo, Titusville, Celebration, Harmony, Avalon, Windermere, Deltona, Debary, Sanford
Orange County, Seminole County, Volusia County, Osceola County
www.homeandmoldinspections.com
Old 3/10/06, 8:22 AM
dplummer dplummer is offline
Please Note: dplummer is a non-member guest and is in no way affiliated with InterNACHI or its members.
As Jay indicated, without a outside sample to compare ,your results are almost useless. Mold spores are part of life, & will travel in & out of our homes. What we want to do is not create a breeding ground for them inside. ie: wet,dirty,humid area's, etc. If your outside sample has readings equal to or greater then your inside readings, you may not have that big of a problem. Don't go to court with your findings. An Industrial Hygienist will hang you. Be carefull! Just my 2 cents Doug
Old 3/10/06, 8:37 AM
I understand the outside air test is important. My question is for my own curiousity. This was my first one and i am imagining that i will not do a ton of these and was curious what kind of results/numbers others are getting both inside and out? I took the Pro-Lab/NACHI/ESA class also. AGAIN, i understand the outside sample is important but at that time and with everyone wanting things now, i could not do an outside. I talked to a Pro-Lab person and they said the Levels were high no matter with an outside test or not. My pen/asp levels were high and if there is a Stach count at all, that is not good.
Anyone care to share their results of test they have done? You won't be telling they are high or low just curious on levels you have gotten. If you want to go into more details, that is great also.
Thanks
Old 3/10/06, 8:50 AM
Greg Bell's Avatar
Greg Bell Greg Bell is offline
The outside sample is MANDATORY if you are working to find out if a client has a problem. The only way to determine if your client has a problem is to retest. IMHO you have provided a service to your client that is of no use. Did you charge the client for the samples that you took? If so I would contact the client and tell them that the tests were inconclusive and that you needed to retest at no charge.
Old 3/10/06, 11:12 AM
gporter's Avatar
You must do some type of outside test. You should have xplained to the client that you could not test because of the outside temp.
Gary Porter
321-239-0621
Old 3/10/06, 11:51 AM
bemelander bemelander is offline
Andy,
Our instructor encouraged us to get an outside reading, if you can't reschedule, Then if that was not possible get one from the garage if the temp is high enough.
His last option, which he discouraged, was to get a comparable from a room farthest away from the suspected mold.
I think this is a learning process for all of us, I would go back and do two more air samples, one in and one out, at no charge.
I'm looking at getting into mold this spring.
Good luck
Bill
Bill Emelander
Professional Edge Home Inspection
Grand Rapids and all of West Michigan
NACHI #03111914
www.proedgehi.com
Old 3/10/06, 12:02 PM
Yes, I could not reschedule so i did the furthest room and upstairs as the suspect problem was in the basement of a 2 story home. Now everyone is slamming me for it. I understand the outside one is important but i couldn't do it. So now i am just asking people for what kind of results they have gotten just for my own comparison and education.
The basement did not have Stach and the main and upper floor did. I thought that was weird. And therefore i have questions for some pros who have done many of these.
Thanks
Old 3/10/06, 1:16 PM
Greg Bell's Avatar
Andy,
Did you tell the client that the samples you were taking would only identify the type of spores found. That without the outdoor sample you would not be able to tell them if they had an elevated condition or not? That the report would state inconclusive?
Old 3/10/06, 1:30 PM
Joseph Hagarty,  CMI's Avatar
High in relation to What?
Without a baseline reference the results are not relevant to anything.
Test would have to be reported as inconclusive and incomplete.
Joseph P. Hagarty, CMI
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 3/10/06, 2:03 PM
I guess basically Pro-Lab said it has Stachy and if you have that, that it is not good.
Thanks and if you all are saying no good on the test due to no baseline, then i will take it from there.
Thanks
Old 3/10/06, 2:17 PM
Greg Bell's Avatar
Good Luck Andy
I hope that everything works out for you.
Interesting article about mold by litigation. gromicko IAC2 Indoor Air Forum 16 5/5/11 8:48 PM
Mold mcyr IAC2 Indoor Air Forum 5 9/13/10 11:31 AM
CMI imposter? jbraun Certified Master Inspector (CMI) Discussion 118 11/26/07 5:55 PM
Mold Remediation & Duck Cleaning Work-If Done Right dplummer Ancillary Inspection Services & Additional Topics 8 10/12/07 3:03 PM
bbbb mcyr Structural Inspections 1 8/19/07 11:26 PM
