When you get your mold reports back from the lab, the report will list the types found. Which ones do you call out as dangerous?
Thanks ahead of time. I am checking for future reference. |
| Find an InterNACHI certified Louisiana Home Inspector (and anywhere else in North America) |
The most common are:
Stachy and Chaetomium. Asp/Pen when the count is more than 10 times the outside count, or more than ten times the detection limit when there is no outside count detected. Also you will need lower counts do to what type of sensitivity. Last school I did was less than 4 times the outside was acceptable. Let your Industrial Hygienist sets your limits. |
Under no circumstances should you be telling clients that one mold is more dangerous than another. You will most definately open up a can of worms that is going to be real hard to close. Do the inspection, get the results and determine if there are elevated levels present. That is it! Scott Gilligan 215-888-4943 Infraspection Institute Level III Certified Thermographer Philadelphia Mold Inspections Philadelphia Home Inspections Philadelphia Commercial Inspections Philadelphia Licensed Home Inspector Pennsylvania - New Jersey - Delaware Infrared Thermal Imaging Inspections President The Greater Philadelphia Chapter of InterNACHI http://pa.nachi.org/greaterphiladelphia Vice President & Webmaster National Association of Commercial Building Inspectors and Thermographers |
IESO
The method you use works fine for testing before remediation just do not perform a clearance on a remediation job using that method. Keep in mind, let your Industrial Hygenist set your limits. I meet my IH while taking the IESO course in St. Louis. Last edited by jbraun; 10/11/09 at 9:11 AM.. |
Good advice from where I sit. Ever see this on the EPA website: http://www.epa.gov/mold/moldcourse/chapter3/lesson3.html "Sampling for mold should be conducted by professionals who have specific experience in designing mold sampling protocols, sampling methods, and interpreting the results." EPA "Experience in interpretation of results is essential.” EPA Maybe that's why the ACAC requires two years experience to apply for a certification. Radon & Mold Professionals Doug Wall, CIE ACAC certified Indoor Environmentalist Florida Licensed Mold Assessor # MRSA 2 Florida Licensed Home Inspector # HI2202 We do not do Home Inspections www.radonmoldhelp.com Radon Testing - Mold Assessments - Mold Inspections - Mold Sampling - IAQ Assessments /Allergen/VOC/Drywall Assessment www.naplesmoldinspection.com |
The sad part is I know inspectors who have been testing for our five years and still cannot interpret samples.
All mold is to be treated the same as far as the inspector is concerned. None is more dangerous than the next, as we are not health professionals, only inspectors. We should not be interpreting test results, as there are no ratified standards yet established which sets limits or flags mold species. A lot is dependent on the health of the one exposed.
James may be the exception to the rule, as he may have the training to understand what he is reviewing. Of course, he needs to be absolutely correct in his interpreataion of face the liability monster. What's good for James may not be goor for the rest, I advise to couch what advice you give to your clients. Since working in a hospital environment, my eyes have been opened to the workings of certain species of mold, and their effects on the sick and immunocomprimised. My suggestion is to research the incidents with aspergilliosis and NY Presbyterian Hospital. When you drill into the data, you will learn that the problem is more pervasive than one may expect, and may be exacerbated by a number of factors. |
Joe is correct.
Even a small amount of Asp. can cause a person problems. I have seen it first hand. |
Thanks for your help. I appreciate it!
James...
Mark this date on your calendar.... We actually agreed on a mold issue... |
| Interesting article about mold by litigation. | gromicko | IAC2 Indoor Air Forum | 16 | 5/5/11 7:48 PM |
| Fighting Mold — The Homeowners' Guide from CMHC | mkyriacou | IAC2 Indoor Air Forum | 1 | 9/17/09 2:32 PM |
| GAO calls for collaboration on indoor mold guidance. | gromicko | Legislation, Licensing & Legal Issues for Inspectors | 32 | 11/11/08 8:47 AM |
| The new scoop on mold insurance | Brian A. MacNeish | Ancillary Inspection Services & Additional Topics | 2 | 1/1/08 1:30 PM |
| CMI imposter? | jbraun | Certified Master Inspector (CMI) Discussion | 118 | 11/26/07 4:55 PM |
