If you don't do the pool inspections yourself please, please, please instruct/demand your clients get a qualified NSPF CPO-CPI inspection or the equivalent prior to closing.
Parents sue pool firm in drowning of their son and if you are doing them how well trained and qualified are you??? ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
Good info, Barry. What a sad event.
With all of our fresh water lakes and rivers, the one or two I see per year get deferred. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Reporting is also important when providing recommendations.
We recommend that there be 2 drains for both Pool and Spa (2 in each area). Covers should be recommended to be anti-entrapment type as opposed to anti-vortex. http://www.usa.safekids.org/water/do...onConsumer.pdf Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
Guidelines for Entrapment Hazards:
Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member Last edited by jhagarty; 2/18/08 at 4:33 PM.. |
This is a new and revised 2008 NEC rule that was developed because of the same type of accident: "680.12 Maintenance Disconnecting Means. One or more means to simultaneously disconnect all ungrounded conductors shall be provided for all utilization equipment other than lighting. Each means shall be readily accessible and within sight from its equipment and shall be located at least 1.5 m (5 ft) horizontally from the inside walls of a pool, spa, or hot tub unless separated from the open water by a permanently installed barrier that provides a 1.5 m (5 ft) reach path or greater. This horizontal distance is to be measured from the water’s edge along the shortest path required to reach the disconnect." Google for IAEI Disconnecting Means |
Adam Veitenheimer is a non-member guest and is in no way affiliated with InterNACHI or its members.
that was horrible... and if this company is so big imagine how many people out there have there drains in there pools... scary stuff.. thanks for the scare tactic, drilled it into my mind...
how many inspectors out there actually go into the pool to inspect, or is that outta the question? how do you know unless you do, just because some things have regulations, doesnt mean that they are calibrated correctly, or that they couldnt have been altered by a "wannabe inventor" that just sold the house... |
Don't interfere with anything in the Constitution. That must be maintained, for it is the only safeguard of our liberties. Abraham Lincoln www.qualityhomeinspectionsfl.com |
| This House Met Code. | jbushart | Electrical Inspections | 88 | 1/16/08 12:29 PM |
| Almost understanding grounding and bonding | Ian Gills | Electrical Inspections | 22 | 12/8/07 2:18 AM |
| Pool question | wward | Ancillary Inspection Services & Additional Topics | 28 | 4/20/07 10:57 PM |
| Pentair Water Pool Gas Heater Recall | Gary Reecher | Inspecting HVAC Systems | 0 | 1/4/07 8:15 PM |
