Does anyone have or know of software to report on Framing Only, Mechanical Only, Final Only, etc, inspections? Maybe a check list of sorts? I have seen a few sights containing phase inspections containing more info than needed. I am looking for something that I can use when performing phase inspections for a builder, not buyer.
Any Help! |
Builders generally have their own QA/QC checklists. Check with the Builder that you will be contracting with to determine what his particualr needs are.
Joseph P. Hagarty, CMI joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
2003 IRC CheckList: Building Provisions with CD-ROM Sample: IX. Wall Construction A. General _____ Wall construction shall be capable of accommodating all loads imposed according to Section R301 and transmitting the resulting loads to the supporting structural elements (Section R601.2). _____ Compressible floor-covering materials shall not be installed under walls, partitions or columns (Section R601.2.1). B. Wood Wall Framing _____ Except as otherwise permitted, studs shall be a minimum No. 3 standard or stud grade lumber (Section R602.2). _____ The size, height and spacing of studs shall comply with Section R602.3.1. _____ Interior nonbearing walls may be constructed in accordance with the following: 1. Two-inch by 3-inch (51 mm by 76 mm) studs spaced 24 inches (610 mm) on center; or 2. When not part of a braced wall line, 2-inch by 4-inch (51 mm by 102 mm) flat studs shall be spaced not more than 16 inches (406 mm) on center; and 3. Interior nonbearing walls shall be fire blocked in accordance with Section R602.8 (Sec. R602.5). _____ Drilling and notching of studs and top plates shall be in accordance with Section R602.6. _____ Header spans for bearing walls shall comply with Section R602.7. _____ Fireblocking shall be provided in wood-frame construction in the following locations (Section R602.: 1. In concealed spaces of stud walls and partitions, including furred spaces and parallel rows of studs or staggered studs at the ceiling and floor level, and at maximum 10-foot "By three methods we may learn wisdom: First, by reflection, which is noblest; Second, by imitation, which is easiest; and third by experience, which is the bitterest." -Confucius Certified Master Inspector (2007) Member, International Assoc of Certified Home Inspectors (InterNACHI) Member, International Code Council (ICC) - Certified Residential Combination Inspector Square-One Inspection "Assurance begins here"
| NC - Board Delays Decision on Facts-Only Home Inspection Reports | jburkeson1 | Legislation, Licensing & Legal Issues for Inspectors | 4 | 11/12/07 1:06 PM |
| Maytag recalls dishwashers. 135 reports of dishwasher fires. | gromicko | Interior Inspections | 2 | 2/5/07 9:07 AM |
