I have encountered a new construction residential pool that has leaching grout between the under water tiles.
This leaching requires a good scrubbing with a brush to remove and I don't know what might cause this. Any ideas? Dale. Dale E. Marwood - Professional Home Inspector Greater Houston Home Inspections Mobile: 832-646-6421 Fax: 832-369-0076 dale@ghhi.biz www.GHHI.biz |
| Need a home inspection in Connecticut? Check out InterNACHI's listing of Connecticut certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
The water chemistry is off. Calcium level may be low.
Comprehensive Building Consultants Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection. Donate here: or send checks to the Fl Home and Insurance Inspector Chapter 1103 W Hibiscus Blvd Ste 311 Melbourne, Fl 32901
Exactly....
is the pool, a new install? particualr attention needs to be made to calcium when the pool is new along with regular / routine brushing. Use of a pumice stone may also be required to remove the scale buildup. Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
Contrary to what the Saleman may have told the Client...
Plaster pools are not Maintenance FREE.... Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
There may be a bigger problem than chemistry. The "leaching you describe may also be caused a void behind the tile.
Pool tile are supposed to be fully embedded in the thin set or mastic. Many "tile men" use just a pat of mortar instead of a full set. This leaves voids that water can get into. When the water gets trapped like this the chemistry in the void causes the calcium build up you see no matter what the chemistry in the pool is. If the problem is bad enough it can actually pop the tile off. The only permanent fix is to remove the tile and do the job right. The same thing can happen with the pool plaster. Have you ever see those calcium "icicles" form. It's caused by exactly the same thing, voids under the plaster coat. In the case of the plaster doing this its usually only a problem if its wide spread or very heavy in a particular area. Other wise you can just knock them off each time they grow back. 5144 Atwood Terrace Inverness, FL 34452 352-212-3576
Actually the calcium would need to be to high for build up to occur
Good posts, Lawrence!
Pete Campbell pete4545@comcast.net http://www.PortStLucieInspections.com http://www.ChooseGI.com http://ifwemissitwewillfixit.com Inspecting Fort Pierce, St. Lucie Village, Lakewood Park, Vero Beach, Indian River Shores, Sebastian, Fellsmere, Fort Drum, Okeechobee, Jensen Beach, Stuart, Palm City, Hobe Sound and Indiantown, Florida. |
Rose Camoro is a non-member guest and is in no way affiliated with InterNACHI or its members.
Use a high quality peeble stone tiles!
Note to Admin: Pls exclude 'guests' who cannot write a legitimate proper sentence!
You don't get the point. It's not the tile it's the installation.
BTW: there IS a spell checker for your posts. 5144 Atwood Terrace Inverness, FL 34452 352-212-3576
| Home Inspector Listings | jbowman | Miscellaneous Discussion for Inspectors | 230 | 3/21/12 9:35 PM |
| Orange County Home Inspections | whandley | California Inspectors | 12 | 5/18/11 6:35 AM |
| New Technology For Pool Inspections | Richard Deverse | Ancillary Inspection Services & Additional Topics | 0 | 3/19/09 12:47 PM |
| Liability question | jcahill | Legislation, Licensing & Legal Issues for Inspectors | 30 | 8/24/08 4:10 PM |
