Old 6/21/06, 4:06 PM
dbucknavich dbucknavich is offline
Please Note: dbucknavich is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Pool inspections/ valve check
I have taken a class about pool inspections but am still unclear about the valve inspection. Where can I find a diagram or instruction about valve inspection? Basically, when I test one valve how do I know which other valves are supposed to be on or off? Any links or tips are geratly appreciated.
Old 6/21/06, 4:33 PM
Jeffrey R. Pope's Avatar
Default Re: Pool inspections/ valve check
What "valve" are you referring to?
Generally, it's not a good idea to operate any of the valves unless you are familiar with the particular system. Many newer systems have automatic (remote) valve operation.
I have a suspicion that you are actually referring to the pressure limit switch for the heater - which is a safety system that should be checked.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
"10 point check list" for Home Warranty Inspections? danderson7 General Inspection Discussion 1 5/14/07 11:16 AM
Pool inspections gkoehl Ancillary Inspection Services & Additional Topics 1 12/15/06 1:12 AM
