Old 4/10/09, 1:09 AM
Joseph Tribuzio's Avatar
Joseph Tribuzio Joseph Tribuzio is offline
Default Radon
Ten facts about RADON:
1. Radon gas is noble & heaviest gas on periodic table.
2. Radon is the largest source of exposure to radioactivity.
3. Alpha particles are emitted from the decay of radon gas;
the impact of the discharge of alpha particles is what
damages lung tissues, not the gas itself.
4. Alpha particles are very light- they have a helium nucleus.
5. Radon is not limited to the basement, the forces that draw it in to the
home will continue to draw it up into living areas.
6. The SURGEON GENERAL , on Jan 13, 2005 issued a
health advisory : RADON CAUSES LUNG CANCER
7. Radon gas is a class A Carcinogen ( group 1)
8. Radon is spontaneous and unpredictable
9. Uranium decay chain leads to Radon which decays
to Polonium, lead, bismuth, and polonium again;
the half lives are relatively short- increasing
potential for exposure to radioactivity.
10. Radon mitigation (reduction) systems CAN also
help reduce mold and other volatile organic
compound gasses, and have been installed
for those purposes.
Joseph Tribuzio 708 453 8447
Tribuzio Home Inspection Services
CHICAGOLAND, ILLINOIS
www.thishomeinspector.com
ID# NACHI07062507
IL Lic#450.003128
Radon lic# RNIT2008216
Home Inspector Pro Software
HIP Web Hosting
Find an InterNACHI certified Alaska Home Inspector (and anywhere else in North America)
Old 4/10/09, 12:21 PM
Default Re: Radon
All depends upon the home, placement, weather conditions, etc. I hope you do not state all of those in every inspection report. Have you taken the iNACHI radon course? If not, I highly suggest it.
Old 4/13/09, 1:40 AM
Default Re: Radon
HUH? --- I am not commenting on measurement of radon in which, yes, placement of the monitor, type of foundation , and weather conditions will effect the readings. I understand that.
however I am commenting on RADON, and that's is why i wrote:
5. Radon is not limited to the basement, the forces that draw it in to the home will continue to draw it up into living areas.
(a true statement to dispel a common myth that it is ONLY found in basements)
8. Radon is spontaneous and unpredictable.
TRUE
No i don't have a need to state these things in a HOME inspection report, but i might mention it to a client while i am performing a Radon Measurement... THESE ARE FACTS, not my opinions.
Well thanks I will take the course, I'm sure it is great, but i happen to already hold a state license in Radon measurement, and just completed a new CE course on the physics of Radon.
Here is another fact:
An improperly installed mitigation system can actually INCREASE radon gas entry in to the home.
Life is learning
ID# NACHI07062507
IL Lic#450.003128
HIP Web Hosting
Old 4/14/09, 6:34 PM
Randy D. Stufflebeem's Avatar
Randy D. Stufflebeem Randy D. Stufflebeem is offline
Default Re: Radon
Life is learning
Dog gone it Joe! You just reminded me I need to get some CEU's?
Good information and some quite powerful as well.
Old 4/14/09, 8:48 PM
Bobby Hamilton's Avatar
Bobby Hamilton Bobby Hamilton is offline
Default Re: Radon
Gary, on your site it states that homes on crawl spaces that are properly vented do not need tested for radon (I see where this would dilute the radon), yet in the same paragraph it states to close off the ventilation when temps are under 25 degrees. Wouldn't you need it tested if your closing off the ventilation?
Radon tests are mostly all taken in basement, under-ground areas, which are the lowest available living areas of a home. If you have a bedroom, office, exercise room or family room below ground level, a radon test is strongly suggested. Homes with crawl spaces generally do not need radon testing, but under home spaces should be properly vented. Check crawl space vents to be sure they are open at all sides of the foundation during spring, summer, and fall seasons. Crawl space access doors should be screened during these seasons for proper cross ventilation. Close crawl space vents when outside air temperatures fall below 25 degrees.
Bobby Hamilton
Bloodhound Home Inspection Services
Youngstown Home Inspection
Austintown Ohio Home Inspection
Providing home inspections, state licensed termite inspections and radon testing in Youngstown, Boardman, Canfield, Poland, Howland, Warren and surrounding Northeast Ohio areas.
Old 4/14/09, 10:24 PM
mnahrgang's Avatar
Default Re: Radon
The comment that homes with properly vented crawlspaces do not need radon testing, is very misleading. Just because the crawlspace is well vented, doesn't mean the home doesn't need mitigation. The home could still have elevated levels, just as a home built in a flood plain on elevated piers could have elevated levels. Radon doesn't get in just through the floor, it can come in through pipes, electrical conduits, an even be brought into the home... Granted, it's not nearly as great a risk in a home like this, but it is still a risk. According the the EPA and NEHA NRPP The only way to know for sure is to test the home, and then re-test every other year.
Mark Nahrgang
www.HeyMark.info
Old 4/15/09, 5:14 AM
dbolduc dbolduc is offline
Please Note: dbolduc is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Radon
I test crawl spaces.
Old 4/15/09, 8:29 AM
mnahrgang's Avatar
Default Re: Radon
I test homes with crawl spaces. According to accepted protocols (US EPA, NEHA NRPP) you are to test in the lowest habitable level of the home. That's either the first floor, or the basement if there is one.
Mark Nahrgang
www.HeyMark.info
Old 4/16/09, 2:01 PM
Douglas Wall Douglas Wall is offline
Default Re: Radon
Just a note:
We have found elevated radon levels in hundreds of high rise condos up to the 27th floor. Many have open parking garages under them.
Last year the EPA gave Florida a grant to study the elevated radon levels in Collier and Lee county high rises (Southwest Florida).
Every time you think a certain structure shouldn't have elevated radon you get surprised.
Radon & Mold Professionals
Doug Wall, CIE
ACAC certified Indoor Environmentalist
Florida Licensed Mold Assessor # MRSA 2
Florida Licensed Home Inspector # HI2202
We do not do Home Inspections
www.radonmoldhelp.com
Radon Testing - Mold Assessments - Mold Inspections - Mold Sampling - IAQ Assessments /Allergen/VOC/Drywall Assessment
www.naplesmoldinspection.com
Old 4/16/09, 6:10 PM
Joe Funderburk, CMI's Avatar
Default Re: Radon
You're not supposed to according to the EPA. Click the link below and see the box to the right.
http://www.epa.gov/radon/pubs/hmbyguid.html#5.a.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 4/16/09, 6:14 PM
Default Re: Radon
Homes with crawl spaces generally do not need radon testing...
I don't know where you came up with that information. The EPA states "ALL" homes at the 3rd level or below should be tested.
http://www.epa.gov/radon/pubs/hmbyguid.html#1.
Theodore Roosevelt
Joe Funderburk, CMI
Old 4/16/09, 6:33 PM
Default Re: Radon
Illinois Administrative Rule (partial)
a) Measurement Location
1) Short-term or long-term measurements shall be made in each lowest structural area suitable for occupancy. For example, a split-level building with a basement, a slab-on-grade room and a room over crawlspace shall have measurements made in each of the foundation types: the basement, a slab-on-grade room and a room over the crawlspace.
A) Measurements shall be made in rooms that can be regularly occupied by individuals, such as family rooms, living rooms, dens, playrooms and bedrooms.
B) Charcoal canisters of any type shall not be placed in bathrooms, kitchens, laundry rooms, spa rooms or other areas of high humidity.
C) Radon in air measurements shall be made either concurrently with or prior to any diagnostic radon in water measurements.
D) Measurement devices shall be:
i) Undisturbed during the measurement period;
ii) At least 3 feet from doors, windows to the outside, or ventilation ducts and out of the direct flow of air from the ventilation duct;
iii) At least 1 foot from exterior walls;
iv) 20 inches to 6 feet from the floor;
v) At least 4 inches away from other objects horizontally or vertically above the detector;
vi) At least 4 feet from heat, fireplaces and furnaces, out of direct sunlight, etc.
E) Measurement devices may be suspended in the general breathing zone and, if suspended, shall be 20 inches to 6 feet above the floor.
F) Measurements made in closets, cupboards, sumps, crawlspaces or nooks within the foundation shall not be used as a representative measurement and shall not be the basis for a decision to, or not to, mitigate the radon level within a building.
Old 4/16/09, 11:28 PM
Default Re: Radon
I agree, this was on Gary's Site Here
Bobby Hamilton
Old 4/17/09, 5:48 AM
Default Re: Radon
LOL! The EPA has a great track record so far. They just follow on behind learning from what the industry is doing.
Old 4/17/09, 7:28 AM
Default Re: Radon
A 27 story building can have 125 "homes" in it. the EPA does not say not to test a building above the 3rd floor.
Doug Wall, CIE
Documents on which InterNACHI's radon course content is based: gromicko IAC2 Indoor Air Forum 4 1/18/09 6:53 AM
Radon Testing Kansas City dmoriconi Ancillary Inspection Services & Additional Topics 1 1/11/09 3:11 PM
Final review of Newman's radon references! Caoimhín P. Connell Ancillary Inspection Services & Additional Topics 12 10/4/08 12:23 PM
Radon Class in Oakville and Ottawa mkyriacou Canadian Inspectors 9 2/2/08 11:48 PM
