I ran across this fan in the attic of a house and wonder if it might be the remains of a removed Radon system. Have included photos of the route to the basement thru a hall closet where there is a loop of tubing also that terminates down in the basement next to the larger pipe that has been cut off in the basement photo.
Not a single label left on the electrical panel, 38 year old house with many "home owner modifications" than forclosed with stuff removed. Some abandoned wiring and controls labeled "pool & Spa" in the basement, not too far from the pipe but no indications in the attic at this spot of condensation like one would expect if this was a exhaust fan from maybe a hot tub down there. Possibly a Meth Lab? Any ideas guys? Gary Bottomley Northwest Michigan Home Inspection Services |
| Need a home inspection in Maine? Check out InterNACHI's listing of Maine certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
It's a mystery Gary but it does not look like any Radon system I have seen.
Write it up as unknown with a recommendation to consult the owner for an explanation. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Thanks Michael:
I haven't seen any systems as we don't seem to run into much Radon around here but I thought I would throw it out just in case I was overlooking the obviuos and should recomend testing (which maybe I will anyway as a CYA). Gary Bottomley Northwest Michigan Home Inspection Services |
BTW Gary... even if it is a Radon mitigation system, and even if you can hear it operating, you would always want to recommend Radon testing to verify the mitigation system is actually doing it's job. JMHO.
| Help. What is the correct way to report a breaker that is too big. | gromicko | Electrical Inspections | 77 | 5/10/12 6:13 PM |
| Washington State Inspectors - Your Deadline Is Near | Mike O'Handley | Legislation, Licensing & Legal Issues for Inspectors | 54 | 4/14/10 9:15 PM |
| Radon Class in Oakville and Ottawa | mkyriacou | Canadian Inspectors | 9 | 2/2/08 11:48 PM |
| Where is it written.... | bgromicko | General Inspection Discussion | 21 | 1/19/08 9:02 PM |
| Ottawa to stiffen radon guidelines. | gromicko | Canadian Inspectors | 1 | 8/16/06 5:28 AM |
