Old 2/6/08, 6:26 PM
David C. Macy's Avatar
Default Radon Mitigation System Checklist
Does anyone have a checklist for inspecting a radon mitigation system?
This home had a system installed and I was hired to do a test. It came back over 8pCi/l.
The system in the garage was blocked by storage/clutter. Could not locate the switch as it was also buried in storage.
Old 2/6/08, 6:40 PM
tdietrich1's Avatar
Default Re: Radon Mitigation System Checklist
I believe if a home has a mitigation system you can only test if it was on continuously, and for 24 hours are more before the start of the test.
Even if you do not live in a state that requires licensing for radon testing, follow the EPA protocol, to keep yourself out of trouble.
imho,
tom <not a lawyer, not the EPA, just an FNG>
Old 2/7/08, 9:06 PM
Richard A. Moran, 2nd Richard A. Moran, 2nd is offline
There should be a fan outside or in the attic that is attached to the Radon system piping. It must be running. There also should be a homeowner visable gauge to show if a differential is being kept on the slab. The system should be working before starting your test. I think 12 hrs but 24 hrs would be safer.
Dick
Dick Moran
True Blue Home Inspections
A Div of RAM2, LLC.
Clarksville, MD
240-832-6838
MD Home Inspector License 29927
Old 2/17/08, 11:19 PM
Brian R. Paull Brian R. Paull is offline
Radon systems generally operate 24/7. I have never seen one with a switch so that the system could be turned off. The only thing that could really be inspected is the U-tube type manometer or other vacuum gauge to assure that the system is operation properly. Also, looking at the electrical connections whether the fan is in the attic or at the exterior of the building is a good idea. EPA protocol also requires a label at every floor that the piping goes through identifying it as a radon system.
Old 1/9/09, 3:41 AM
Nick Gromicko's Avatar
http://www.nachi.org/comsop.htm#18
Find a Home Inspector
Old 1/9/09, 4:50 PM
Part of our new radon course: http://www.nachi.org/radoncourse.htm
Radon Class in Oakville and Ottawa mkyriacou Canadian Inspectors 9 2/2/08 11:48 PM
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 5:58 PM
Ottawa to stiffen radon guidelines. gromicko Canadian Inspectors 1 8/16/06 5:28 AM
Radon mitigation system at neighbors house? jsmith3 Ancillary Inspection Services & Additional Topics 3 5/20/06 8:42 PM
