I’ve been doing a lot of research and I’m getting ready to pull the trigger on a Sun Nuclear 1030. Those of you that are using them currently, do you like them and are they worth the additional upfront costs? Any pros/cons compared to the 1028 or other makes/models? Thanks for the info.
I read that post. What did you end up going with?
If you can afford the 1030 go for it. I have really liked it so far (about 10 tests)
I had an report today that had the humidity out of control 100%.
The 1027 can not record temperature, pressure and humidity.
