Old 3/10/08, 8:57 PM
Robert A. Jack Robert A. Jack is offline
Default radon in water
I just completed a water and radon air inspection with radon in water. The radon in air was slightly elevated at 4.2 and 5.4. The question is the radon in water cam back at 8745. This is a brand new home with a drilled well. Does anyone have any take on the radon in water level? I See the EPA has yet to establish any firm guidelines. Any big concerns on this level?
Old 3/10/08, 9:09 PM
Troy Farmer's Avatar
Troy Farmer Troy Farmer is offline
Default Re: radon in water
http://www.epa.gov/SAFEWATER/radon/remove/fact.html
Check this out
Troy Farmer
Presidential Inspections LLC
Chapter President Southern Idaho
PO Box 2144
Eagle, Idaho 83616
208-573-5300
http://www.presidentialinspection.com
http://info@presidentialinspection.com
"He who can, does. He who can’t, teaches"
"Where would we be without Teachers"
Old 3/10/08, 9:13 PM
Radon also can enter a home if a water supply contains dissolved radon . Private water wells drawing from water with dissolved uranium or radium are most likely to have potential radon-associated health risks. Private wells usually do not have treatment systems and the short transit time between the pump and the home does not allow enough time for radon decay. According to the EPA, most risk is still from inhalation rather than ingestion because household activities such as showering and laundry release radon to the indoor air. Approximately 10,000 pCi/L of radon in water contributes about 1 pCi/L of radon to indoor air (Zapecza and Szabo, 198.
Radon is usually not a problem in large public water supplies because water is generally obtained from multiple sources or surface water. Mixing, treatment aeration, and longer residence times within the treatment system promote dilution, off-gassing, and decay of radon (Zapecza and Szabo, 198.
Troy Farmer
PO Box 2144
Eagle, Idaho 83616
208-573-5300
Old 3/10/08, 9:14 PM
An Actual link, this is good stuff
http://www.bae.ncsu.edu/programs/ext...qwm/he396.html
Specific Section:
(Radon 222) is a naturally occurring radioactive element measured in picocuries per liter (pCi/L). Radon is produced during the radioactive decay process of uranium that has been in the earth's crust since the earth was formed. In water, radon is measured in picocuries per liter (pCi/L). A picocurie is 0.037 radioactive disintegrations per second. The EPA estimates that 10,000 pCi/L in water translates to about 1 pCi/L in air.
Troy Farmer
PO Box 2144
Eagle, Idaho 83616
208-573-5300
Old 3/11/08, 8:11 AM
Doug Wall's Avatar
Doug Wall Doug Wall is offline
Please Note: Doug Wall is a non-member guest and is in no way affiliated with InterNACHI or its members.
The EPA stated in an article, last year, in the miami paper that 4.0 pCi/l was equal to about 200 chest xrays a year.
Something I always thought was interesting.
Doug Wall
www.radonmoldhelp.com
Old 3/11/08, 8:19 AM
Gary Oleski Gary Oleski is offline
Connecticut Department of Public Health has a recommened guideline of
5,000 pCi/L in private well water for radon.
Gary Oleski Home Inspections
Home Inspections Connecticut
Connecticut . 06610
NACHI04012833
CT#HOI.341
C M I
Radon Class in Oakville and Ottawa mkyriacou Canadian Inspectors 9 2/3/08 12:48 AM
Ottawa to stiffen radon guidelines. gromicko Canadian Inspectors 1 8/16/06 6:28 AM
