Ancillary Services & Additional Topics Contains discussions about Radon, Wood Infestation, Water Quality, Well, Septic, Lead, Asbestos, Pool, and Mold inspections.
| Need a home inspection in Minnesota? Check out InterNACHI's listing of Minnesota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
It's all in the title, so I would say anything! Can-Am Home Inspections Inc. Level 1 Thermography Specializing in Building Infrared Thermography ProLab Certified INACHI #09113003 IAC2 #01-8254 www.can-amhomeinspections.com |
It appears to be mainly about dryer vent cleaning.
OK, lets talk about mold testing.
IF you are testing what are your qualifications, what testing devices, lab are you using, what tools do you use for mold testing, inspecting? How much are you charging for inspecting? Testing? |
If you are just going to do preliminary testing, the IAC2 is all that you really need. If you are wanting to determine why somebody is sick, guide a remediator on how to remove mold correctly or get involved in legal cases, you will need to spend a lot of time in school and most likely work under a mentor.
I use Springfield Indoor Air Quality because the Industrial Hygienist, who is the top mold expert in Missouri, analyzes the samples himself. He gives good guidance in case I find something difficult out in the field. His number is (417)823-7427. It is best to call him during the evening because he goes out in the field a lot. If you get on his good side, he will bend over backwards to help you. FedEX did not deliver one day, because of snow, so he went to the FedEx office himself and picked up my samples for I would have a fast turn around time. His rates are with everybody else, if not cheaper. He will send you new air cassettes and tape samples, replacing the ones he has analyzed at no extra charge. He looks at slides at higher magnification and reads more of the slide than most labs. I get $125.00 per sample. Inspection prices very, it all depends on what they are wanting to know. |
Damn sounds like a good guy!
Comprehensive Building Consultants Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection. Donate here: or send checks to the Fl Home and Insurance Inspector Chapter 1103 W Hibiscus Blvd Ste 311 Melbourne, Fl 32901
| Washington HI licensing information from DOL | hmiller | Legislation, Licensing & Legal Issues for Inspectors | 182 | 10/3/09 12:14 AM |
| Democrats Enacting Gun Control - I Told You So..! | jmckenna1 | Miscellaneous Discussion for Inspectors | 42 | 2/17/09 1:38 PM |
