Old 10/3/09, 9:43 PM
Jonathan N. Leahy Jonathan N. Leahy is offline
Default Something Missing on this Pipe?
This radon mitigation system was installed at a property I tested today. Shouldn't the top of the pipe have a U-shaped or gooseneck anto it?
Thanks
Jonathan
Jonathan N. Leahy
President
A Rock Solid Home Inspection, LLC.
www.arocksolidhome.com
303-718-7779
Residential Home Inspections, Radon Testing, Mold Inspections
Find an InterNACHI certified Georgia Home Inspector (and anywhere else in North America)
Old 10/3/09, 9:51 PM
mnahrgang's Avatar
Default Re: Something Missing on this Pipe?
Yes and it should also be above the roofline.
Mark Nahrgang
www.HeyMark.info
Old 10/3/09, 10:21 PM
David P. OKeefe's Avatar
David P. OKeefe David P. OKeefe is offline
Does it have to go above the roof line if there are no windows or openings nearby?
David
InterNACHI #08051301
NYS Lic. #16000038229
NYS DEC Cert # T4865884
518-505-8305
HouseAbout Home Inspections
HouseAbout on Facebook
NY Capital Region Chapter InterNACHI
Old 10/3/09, 10:48 PM
mnahrgang's Avatar
I'm not 100% sure because I don't do mitigation, but I believe so. Yes.
However, I did a radon test on a home that had a similar setup (garage side of the home). Radon levels were below 2.0 so apparently there was no negative effect.
Mark Nahrgang
www.HeyMark.info
Old 10/4/09, 6:20 AM
Gary Oleski Gary Oleski is offline
What Mark said.
Gary Oleski Home Inspections
Home Inspections Connecticut
Connecticut . 06610
NACHI04012833
CT#HOI.341
C M I
Old 10/4/09, 8:01 AM
Yep.
Radon reduction systems must be clearly labeled. This will avoid accidental changes to the system which could disrupt its function.
The exhaust pipe(s) of soil suction systems must vent above the surface of the roof and 10 feet or more above the ground, and at least 10 feet away from windows, doors, or other openings that could allow the radon to reenter the house, if the exhaust pipe(s) do not vent at least 2 feet above these openings.
Old 10/4/09, 9:02 AM
David A. Andersen's Avatar
It must also have a "U-Tube"' manometer installed on it also (not so you can look at U-Tube videos either...)
BPI# 5015804
Old 10/4/09, 9:57 AM
This pipe did discharge at least 10 feet above grade. The house tested below 1.0. The house next door also had a mitigation system as well. The manometer and vent pipe on the interior of the property was clearly marked.
Thanks
Jonathan
Jonathan N. Leahy
President
303-718-7779
Old 10/4/09, 1:58 PM
mnahrgang's Avatar
Thanks
Jonathan
In that case I would note it, tell the buyers about the "issue" but not make a big deal of it.
Mark Nahrgang
www.HeyMark.info
Do you put polybutylene in the Summary? jfunderburk Plumbing Inspections 41 4/5/12 6:43 AM
Pellet stove help chellickson General Inspection Discussion 23 8/19/10 1:23 AM
Is this allowed? belliott Plumbing Inspections 4 7/15/09 6:40 PM
Help - Polybutylene Pipes Rick G Plumbing Inspections 39 2/12/09 8:16 AM
Identify ABS defective pipe mcyr Plumbing Inspections 6 1/29/09 6:39 PM
