Old 10/30/06, 7:58 PM
Yuri Olhovsky's Avatar
Yuri Olhovsky Yuri Olhovsky is offline
Default Are there soil specialists here?
On the inspection today I saw few of these piles at back yard. The house is empty, so I could not ask anyone. Initially, I thought it's an aggregate or gravel covered with dirt. But when I probed it with my foot, it is all soft (you can see dents from my shoe here) It looks like a pile of mud with consistency of a dough. I wouldn't worry if it will be just one. But there were at least 3-4 of those, and all had exact same look. Does anybody know what it could be?
Yuri Olhovsky CMI, CEA, PHPI, RASDT
National Home Inspector NHICC #00372
Richmond Hill, ON Canada
NACHI ID 04070207
Old 10/30/06, 8:00 PM
Dale Duffy's Avatar
Default Re: Are there soil specialists here?
Looks like a Mole was working.
Old 10/30/06, 8:12 PM
Emmanuel J. Scanlan Emmanuel J. Scanlan is offline
In our neck of the woods that would be a crawfish mound. Did you scrape it to the surrounding earth to see if there was an entry hole under it?
Knowledge is power, but sharing knowledge brings peace!
http://www.psinspection.com
TREC License# 7593
Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC!
Old 10/30/06, 9:37 PM
tneumann's Avatar
tneumann tneumann is offline
Mole here too..or vole...
Old 10/30/06, 10:01 PM
Mark H. Roe's Avatar
Mark H. Roe Mark H. Roe is offline
from the picture I would have to vote for a mole hill. If they were close to water, I would vote for a crawdad hole. Either way. not much of a problem.
Old 10/30/06, 10:30 PM
Thanks everybody for replies. Living in big city, I have never seen this before. That is why I was wondering. Learning something new on each inspection. Thanks again.
NACHI ID 04070207
Old 10/30/06, 11:01 PM
Dale Duffy's Avatar
Old 10/31/06, 12:31 AM
Gerry Pallotta's Avatar
Gerry Pallotta Gerry Pallotta is offline
Send a message via Yahoo to gpallotta
Crawdads are crayfish are they not? I did not know they came out of water.
Gerry
Old 10/31/06, 3:59 AM
Russel Ray's Avatar
They create trip hazards.
Trip hazards are a major cause of accident and injury around our homes, and accidents and injuries are a major cause of lawsuits. Never fail to mention trip hazards in the landscape and hardscape, regardless of what one believes has created the trip hazards.
Old 10/31/06, 4:22 AM
Yuri
Just remembered Mud/Sand Wasps make that kind of mound as well did you see any critters flying around.
Gerry
Old 10/31/06, 5:11 PM
I see piles like that all over around here and they're the entrances to vole tunnels: NACHI Wildlife Damage Inspection course. http://icwdm.org/handbook/rodents/Voles.asp
Google Images: vole mounds
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 10/31/06, 5:41 PM
Brian E. Kelly's Avatar
Yuri I believe you should consult a Certified Mole Inspector to verify your findings.
Old 10/31/06, 11:46 PM
William Warner's Avatar
William Warner William Warner is offline
Correct me if I'm wrong, but...
Mole / vole hills or mounds resemble loose piles of excavated dirt (when relatively fresh) with an entrance hole anywhere in the mound. They may be more compact or solid after a rain. Size should be somewhere between 6 inches and 12 inches in diameter at the base
Crayfish mounds typically resemble cone shaped mounds of 3/4 - 1 inch diameter mud balls which have fused together and the entrance hole is typically at the very top. (Resembling a volcano) Size should be typically 4 inches to 8 inches at the base depending on the size of the "engineer". I have seen these as far away as 50 yards from a visible source of water, but only when there is a high water table present and typically in high peat type soils. I used to use them as fishing pole holders as a kid if that gives you an idea of the size of entrance/exit hole.
Visit the InterNACHI Awards web portal here
Blessed are the blissfully ignorant... for they shall be easily led...
Old 11/1/06, 9:30 AM
William,
Yes, when constructed and no further rain is present, crayfish holes here do resemble your description. After a soaking, in our soils, they begin to collapse and start looking like the piles shown. Kicking them usually uncovers the hole underneath and they can get quite deep!
Not sure up north how much of a crayfish problem they have but here it can get downright bad. I've found them all over my property (10 acres and a tank, Texas speak for pond) and them buggers can get big and nasty! I've watched them gather and take out a large dog once that got to close to their party area (LOL LOL) (just kidding of course).
</IMG></IMG>
TREC License# 7593
Old 11/1/06, 10:25 PM
</IMG></IMG>
That's good But hey... everythings big in Texas!
something else to chew on john bubber Structural Inspections 662 1/31/12 2:33 PM
A sinking Home rcooke Miscellaneous Discussion for Inspectors 0 8/12/07 8:28 AM
Soil Testing Mike Jewett Ancillary Inspection Services & Additional Topics 2 7/20/07 8:43 AM
