Most homes we inspect that are built before 1980 have Transite Vent flue pipe. As we all know Transite pipe contains asbestos. If the pipe is still in use and not cracked or loose, should I report that the pipe exsist and recommend removal?
| Find an InterNACHI certified Hawaii Home Inspector (and anywhere else in North America) |
Point it out as it may contain Asbestos.
Good link on the subject here for your information.
http://www.inspect-ny.com/sickhouse/asbestoslook7.htm LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Agreed. Give them the facts and let them make the decision to remove it or not.
Bobby Hamilton Bloodhound Home Inspection Services Youngstown Home Inspection Austintown Ohio Home Inspection Providing home inspections, state licensed termite inspections and radon testing in Youngstown, Boardman, Canfield, Poland, Howland, Warren and surrounding Northeast Ohio areas.
Point it out as it may contain Asbestos however not dangerous until cracked or loose or whatever else scenerio you may think of. I would be specific. You don't want to alarm them for no apparent reason.
Bill Boerner STL Home Inspection Services LLCServing St. Louis/Surrounding (314) 805-2137 office@stlhomeinspector.com http://www.stlhomeinspector.com Residential, Commercial, Radon, Termite, Lateral Sewer Scopes |
Thanks.
I pretty much tell everyone to replace it as 1, they are always installed to close to combustible material; and 2 just because of the age the Transite material could be deteriorated and pose a potential fire hazard.
The asbestos in the Transite pipe is a "non issue" as far as I'm concerned - except when it comes to removal and disposal.
The "danger" in these pipes comes in the form of cracks, which may be too small to see. I recommed as a "Recommended Safety Upgrade;" Quote:
| Help - Polybutylene Pipes | Rick G | Plumbing Inspections | 39 | 2/12/09 8:16 AM |
| New Washington Legislation Submitted | gdomagala | Legislation, Licensing & Legal Issues for Inspectors | 294 | 2/10/08 1:20 AM |
| vent pipe in attic | brepanshek | Inspecting HVAC Systems | 2 | 3/6/07 2:32 PM |
| Electric pipe warmers in attic | hspinnler | Plumbing Inspections | 2 | 6/29/06 12:08 AM |
