New one (unusual installation) and I am looking for information with regard to the remediation and removal of UFFI.
In this particular situation, the UFFI foam may have been installed within the wall cavities of the home. Home was renovated and added onto with a 2 story addition. The UFFI was recycled and the blocks were broken up and strewn throughout the Attic. the Attic now has a loose fill installation of UFFI Foam. Comments? Suggestions? References for remediation? Joseph P. Hagarty, CMI joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member Last edited by jhagarty; 2/18/08 at 5:34 PM.. |
I would imagine this would have had plenty of time to "cure" by now, so the risk of the UF venting at this point is next to nill. The major risk I can see of this is that if the roof were to leak, UFFI has a tendancy to mold when wet. Google "UFFI" and you'll see bunch of links, mostly talking about Canadian lawsuits.
Hi. Joe, hope you are doing well.
Would like to add this in case it helps someone. UREA FORMALDEHYDE FOAM INSULATION (UFFI) Urea Formaldehyde Foam Insulation (UFFI) was used in the early 1900's in many residential and commercial buildings as a subsequent or main insulating material in walls and ceiling spaces. Liquid foam was sprayed into an area to be insulated where it expanded to completely fill the space and hardened. Unfortunately it was found that this type of foam insulation emitted toxic formaldehyde fumes causing serious respiratory health effects. Subsequently many homes and commercial buildings had the foam removed by qualified contractors.However, many structures still have the UFFI material in place. In many instances, however, building owners are unaware that their building contains UFFI. Identification of UFFI can avoid potential health and safety issues for the contractor and liabilities for the owner and architect. Environ will arrange an independent consultant for hazardous materials and other potential environmental concerns on residential, commercial and industrial properties. Each assessment includes sampling of all suspected hazardous materials, confirmatory laboratory analysis and complete reporting of all findings. We can also complete specifications for any required remedial activities and perform project management services. UFFI REMOVAL In order for all UFFI to be removed, a careful exposure of all UFFI on the premises is required along with a mechanical removal of the foam. In addition, surfaces that have been in contact with UFFI must be properly washed and allowed to dry. Independent inspections testifying to the completeness of the removal is both appropriate and required. Air quality tests after the removal procedures and the neutralization of the surfaces with which UFFI has come into contact are also needed. UFFI INSTALLATION UFFI was installed by using pumps and hoses with a mixing gun to mix the foaming agent and the resin, to produce a "Shaving Cream" product called Urea Formaldehyde Foam Insulation (UFFI). The UFFI was installed under air pressure, up to 100lbs. of air pressure per square inch (psi) and injected through 1/2" - 2" holes in mortar joints, drywall, wood siding, aluminum siding, concrete blocks, etc.. Almost all forms of construction had UFFI installed. UFFI was also used as sound insulation, air sealant in commercial and industrial and has been found in attics, common walls of row houses or semi-detached homes, office walls, apartment buildings, condominiums and garage ceilings where rooms are over garages. Because if the installation procedures which involved extreme air pressure, UFFI has been found in many areas in which it was not supposed to be: -air sealant around columns and electrical outlets and switch plates -windows and electrical boxes -foundation blocks and sill plate -attic and knee wall areas -basement perimeter sill and floor joist plate duct work -fireplace chimneys -floor joists and ceilings between floors -abutting wall attached walls where UFFI was installed -between double brick -between brick and cinder block -between block or brick and plaster -in soffits -in veranda overhangs -under bathtubs -in bay window boxes -around noisy pipes in bathroom -around plumbing -used as a sealing material (anywhere there was a cold draft UFFI could have been used) Of course, UFFI is most extensively found in walls or residential homes in one of two ways. It could be installed through the exterior sheathing, brick block, wood or aluminum siding, shingles, or cedar shakes - in some cases, prior to new siding being installed or the shake or shingle removed, and then, reinstalled covering the holes with wood and plastic plugs, mortar, etc.. Alternatively, it could be installed from the interior by drilling holes through plaster and lather, gyprock or drywall - in most cases holes were re-plastered or covered with wallpaper. If you have recently found or suspect UFFI and are looking for more information, please call. Urea Formaldehyde Foam Insulation (UFFI) is as controversial today as it was in December of 1980 when the first temporary ban was put into place. Discussing health concerns and questions are beyond the scope of our expertise; however, we can advise you that there is a great deal of disagreement over UFFI. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
One of these bricks could be compressed to powder that would fill a tablespoon.
This is the first time that I have encountered someone recycling UFFI. Is there any particular concern as to the current placement of the Insulation? Joseph P. Hagarty, CMI joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
Formaldehyde Formaldehyde has been classified as a probable human carcinogen by the EPA45. Urea-formaldehyde foam insulation (UFFI), one source of formaldehyde used in home construction until the early 1980s, is now seldom installed, but formaldehyde-based resins are components of finishes, plywood, paneling, fiberboard, and particleboard, all widely employed in mobile and conventional home construction as building materials (subflooring, paneling) and as components of furniture and cabinets, permanent press fabric, draperies, and mattress ticking.
Airborne formaldehyde acts as an irritant to the conjunctiva and upper and lower respiratory tract. Symptoms are temporary and, depends upon the level and length of exposure, may range from burning or tingling sensations in eyes, nose, and throat to chest tightness and wheezing. Acute, severe reactions to formaldehyde vapor -- which has a distinctive, pungent odor -- may be associated with hypersensitivity. It is estimated that 10 to 20 percent of the U.S. population, including asthmatics, may have hyperreactive airways which may make them more susceptible to formaldehyde's effects46. Most home insulated with UFFI had indoor air concentrations of under 0.1 parts per millions (ppm) one year after installation .However UFFI when exposed to extreme heat or moisture can begin to emit formaldehyde vapors no matter how old the insulation. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
My wife is allergic to just about every thing and I to many things.
We had UFFI in one of our homes and saw nothing wrong with it . I would not hesitate for a second buying a home with UFFI . If some one has concerns then put in a HRV unit . This is what Carson Dunlop says . http://www.nachi.org/forum/showthrea...321#post213321 CMHC has a report also will try and find it Added later http://www.cmhc-schl.gc.ca/en/co/mah...inaiqu_008.cfm https://www03.cmhc-schl.gc.ca/b2c/b2...00240000000007 If I can answer any questions please send me email Roycooke@hotmail.com On an inspection and need immediate help call my cell 613-827-2011 Last edited by rcooke; 6/9/07 at 10:10 PM.. |
I have had two homes with it installed. Never any problems.
A hrv is constantly taking the inside air and exhausting it out side and bringing in fresh out side air into the home . This lowers the moisture and smells inside the home it also would be removing and Formaldehyde fumes if they existed. https://www03.cmhc-schl.gc.ca/b2c/b2...00450000000017 If I can answer any questions please send me email Roycooke@hotmail.com On an inspection and need immediate help call my cell 613-827-2011 |
| IAC2 In new residential construction | mcyr | IAC2 Indoor Air Forum | 0 | 10/9/07 7:45 PM |
| More on UFFI | rcooke | Canadian Inspectors | 4 | 7/21/07 10:51 PM |
| Vaulted Ceiling Insulation | rcooke | Canadian Inspectors | 3 | 1/22/07 11:24 AM |
| New Old Insulation | rcooke | Canadian Inspectors | 1 | 12/13/06 6:25 PM |
| Crawlspace Insulation | gbrasseur | Structural Inspections | 12 | 12/3/06 4:18 PM |
