Old 9/10/07, 12:11 PM
Scott C. LeMarr Scott C. LeMarr is offline
Question Unusual Home for this area has elevated levels
Just looking for some experience probably from our southern group. Our area is almost exclusivly housed with basements. I was called to a house recenlty due to musty odors. I preformed four air quality tests (one outside) and test results did show that the home has elevated levels of Aspergillus and Penicillium. This house is a one story ranch that is built on a slab and into a small hill. There is no basement. It appears that the floor joists rest directly on the slab. I am suspect of the wall built into the hill (the entire south side)but cannot see under the floor without drilling holes or cutting wood. I have not yet found the source of the mold and am looking for any ideas (preferably non destructive) for being able to see under the floor. The only vent (to the underside) I found is in the furnace room and the furnace is blocking my access. I am headed back on Thursday 9/13 with some ideas but I am always open to suggestions from others.
Thanks,
Scott
Scott C. LeMarr
Honest Home Inspections, LLC
Master Indoor Environmental Specialist (MIES)
Certified Mold Inspector & Assessor
Certified Weatherization Inspector for WI
262-424-5587
www.HonestHomeInspections.com
www.MilwaukeeMoldInspector.com
Old 9/10/07, 5:01 PM
Barry Adair's Avatar
Default Re: Unusual Home for this area has elevated levels
Scott,
No expert on screed slabs
My total experience is 6
They ranged from late 40's through the 80's, at least one from each decade
What I do know is the ones I've seen had no vapor barrier, no post tension all were rebar, and all were wet.
This was due to moisture migration, air leaks at ducts we do a lot of AC here, and plumbing supplies entering through the slabs that did not have proper protection. Moisture meters and IR can point out these locations.
I've gotten some limited views from removing duct grills either at the floor or returns at walls.
What I do on suspect slab leaks is turn off all interior and exterior water fixtures at there everyday knobs.
Go to the meter and if the test dial is spinning you may very well have a leak.
I go back inside and start turning off service stop valves at the commodes one at a time, maybe just a bad flapper.
After all commodes are off if the meter is still running it's time to call the slab leak pros.
Good luck!
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 9/10/07, 7:11 PM
gbeaumont's Avatar
Hi Scott,
That may well be a candidate for an Infrared camera inspection also a good moisture meter may tell you a lot.
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 9/10/07, 7:25 PM
Gerry,
Good advice!
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 9/10/07, 7:32 PM
Doug Edwards's Avatar
Im just curious; at what point would one stop looking for the mold and call the experts? Sounds as if the initial work has been accomplished through the taking of the air samples. I am trying to understand where the line stops at doing mold sampling and starts becoming something more. What happens if you never actually find the mold? Is that the end of it or is there another step or protocol to follow?
- John Stuart Mill
Old 9/10/07, 9:51 PM
wsiegel wsiegel is offline
ditto what Gerry said
Old 9/10/07, 10:17 PM
Banned
A quote by the best known North American building scientist:
"If you see it or smell it, you do not have to test for it. It is more important to get rid of the mould rather than spend a lot of money trying to find out more about it." (by sampling and identifying the species of mould- my comment)
Dr. Joe Lstiburek, P. Eng., Phd.; Building Scientist and principal at Building Science Corporation (Website: www.buildingscience.com)
Testing may have been an unnecessary step here!
Old 9/11/07, 9:39 AM
gbeaumont's Avatar
Quite possibly, if a home smell musty & moldy you allready know it is going to have mold, the only real reason to take air samples is to establish a base line so that a post remeadiation clearance test has something to be judged against. The big issue here should be finding the cause of the moisture intrusion.
Regards
Gerry
(Mark B Adams)
NACHI02121106
Old 9/11/07, 3:29 PM
Richard A. Moran, 2nd Richard A. Moran, 2nd is offline
If you are called in to test for mold then you are required to look for red flags and then test to prove what you have found. As far as looking for the source of the mold did you see mold or did you just get air samples? The Lab will give you a report showing what it found which your nose may not be able to do. If the family has been sick then the report could be also used by a doctor. If I paid someone to come and test my house and all they did was walk in and sniff I may not be happy. If the joists are sitting on the slab and there is no moisture barrier between the slab and the wood then you have a problem.
Your mileage may vary....
Dick Moran
Clarksville, MD
Old 9/12/07, 11:48 AM
Question Re: Unusual Home for this area has elevated levels
All good information thank you for your input. And "yes" to the question just how far do I go? I took the air samples becuase the ederly ladies who live there asked me to. And I took more than normal as I was trying to create a base for later testing once the problem had been discovered. The other issue was that I could not see anything so I did the tests and the highest levels were in the family room which gives me a place to concentrate.
Now the next question does come..........How far do I go, how much time do I spend and how much do I charge them for the time I spend there? Of course I made some money off of the tests. How many times do I go back to try to find the source? When do I call in the experts and am I not the expert?..........Not on this type of construction that's for sure.
My suspect at this point is the return ducts that, I believe, are utilizing the floor joists sitting on the slab...........you know where this is going. I noticed when I turned on the furnace fan that the smell became stronger. One of the ducts may allow a mirror and flashlight. That is my next step tomorrow unless someone out there has any better ideas!!
Old 9/12/07, 12:22 PM
Richard L. Bennett Richard L. Bennett is offline
Please check HVAC drain and air handler area
Mold heaven in my area area if stopped up
Don't much in duct work
Don't forget old fashion dirt - carpet and furnisher
If sometimes people let these things get out of hand an stuff starts to grow
Hopefully a good flashlight will find what you are looking for
Good luck
rlb
Old 9/12/07, 2:16 PM
Jeremiah Anderson's Avatar
Jeremiah Anderson Jeremiah Anderson is offline
Hi Scott,
These questions are best answered before you even step foot into the place by establishing the scope of your services to the customer. Of course, this does not help you in this situation now--but something to ponder for the future. As far as charging for your time, come up with what your hourly rate is and then bill in 6 minute increments as other professional consultants would do.
It is highly possible when working on these cases that you will receive phone calls from the "specialists" and may even be requested to attend various 3rd party inspections where the destructive testing will occur. This is what seperates the inspectors from consultants. You need to decide if you will attend these events, which I do, and what you will charge for your time on an hourly basis. Then make sure the customer understands all of this and have them sign to put it in writing. These cases can linger on for years. I inspected a house in the fall of 2005 for a moisture intrusion situaiton and it was just finally resolved in the spring of 2007. I spend about 4 hours of actual inspection time on the property over two seperate occasions and logged about 10 hours of follow up time in the form of phone calls, and attendance at two third party inspections. All was billed back to the customer.
Jeremiah
Old 9/12/07, 11:17 PM
mnahrgang's Avatar
Originally Posted by slemarr
... the ederly ladies who live there ...
... I noticed when I turned on the furnace fan that the smell became stronger...
Two things you mentioned that triggered a memory... elderly ladies & furnace fan. You're in WI so that implies that the furnace is in use a big part of the year. I know some elderly ladies up north that are very concerned with their wood furniture getting too dry in the winter.
Is there a humidifier by chance, on the furnace? Those things are professional level petri dishes.
Mark Nahrgang
www.HeyMark.info
Old 9/13/07, 1:58 PM
Just left the "mold house" as I am now calling it (certainly not to the customer). There is no humidifier in the house, they are using a dehumidifier. In fact I asked them if they even needed one in the winter and they said no as I expected. The return ducts are not ducts at all just vents cut into the floor. The return air is sucked through these vents over the cold slab thus warming it and creating moisture. This moisture keeps the house at a good humidity level but must be destroying the floor joists that I cannot see.
I can see just enough to understand that the support is a series of 2 x 6 in a cross pattern to allow the air to flow in between the floor joists. A poor design at best but one they will have to live with. This house is built into a hill and about 4 feet of the North side is in soil. My suspect is this wall but there is no access to see anything. My next step is to contact another inspector who has a termal imaging device and see what we can using this. We also discussed using a media type filter with a UV light just to get them some relief from the poor air they are living in. Always willing to listen for other suggestions, opinions, etc.
Scott
Old 9/14/07, 12:21 AM
How do you know it's not soil-borne bacteria? I'd recommend a specialist and be out of there.
I'm with Gerry on the thermal imaging and Brian on finding out exactly what it is.
Find the source of moisture and correct it. If the smell continues, recommend an industrial hygienist.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Inspector listings by county rcarter Miscellaneous Discussion for Inspectors 8 8/22/09 10:40 AM
USA case law on Home Inspection rwand1 Canadian Inspectors 10 5/23/09 11:30 PM
Home Inspector Listings Part Two jbowman Miscellaneous Discussion for Inspectors 8 8/29/06 8:52 PM
Ohio Licensing Questions jmurray Legislation, Licensing & Legal Issues for Inspectors 11 1/17/06 6:00 PM
