Old 1/19/06, 8:38 PM
mmckague mmckague is offline
Default water and septic inspections
I recieved a call for a well and septic inspection and am wondering what the finance companies are needing as far as a report goes. anyone have the answer?
Old 1/19/06, 8:55 PM
Greg Bell's Avatar
Greg Bell Greg Bell is offline
Default Re: water and septic inspections
Hi Michael,
In Florida you need to be a state licensed septic contractor to inspect septic systems. I always recommend that they call a septic company.
Old 1/19/06, 10:23 PM
Jay Moge's Avatar
Jay Moge Jay Moge is offline
Originally Posted by gbell
Hi Michael,
same here, plus i don't have a "cucu sucka" and don't believe anyone can realy "inspect" a septic without that and a pressure washer. as for the well, i differ anything underground. i can't inspect it if i can't get to it, and calling Dig Safe or other co. isn't part of a home inspection for me.
Old 1/19/06, 11:27 PM
ya thats what I figured guys, I didnt really want to dig in where i really didnt want to go, but talking to this finance lady there is a demand for the service there, but I just want to visually inspect, not dig in. thanks for the input
Old 1/20/06, 8:54 AM
William A. Poole's Avatar
William A. Poole William A. Poole is offline
I get a few calls a year to do septic mapping. This is mostly for FHA loans.
Old 1/20/06, 11:26 AM
Mark Reagin Mark Reagin is offline
Please Note: Mark Reagin is a non-member guest and is in no way affiliated with InterNACHI or its members.
Septic Inspections are risky legally, according to a local Indiana Septic Service provider. To pump the system and inspect the tank visually would be advisable for a buyer. However, the septic company will not be able to give any assurances that the new owners will "fit" this septic tank because of differing household water use habits as well as factors like the soil type and compaction affecting the leach fields ability to safely process liquids above certain volumes. So if you provide this service or even subcontract it out, be well versed on the subject and be prepared for potential legal problems.
Old 1/26/06, 2:16 AM
The National Association of Wastewater Transporters (NAWT) offers a 2-day certification course in inspecting septic systems which is considered to be very good by the county and state people I've talked to (Colorado).
There appears to be a lot of misinformation about inspecting septic systems floating around out there. It's a high-liability business. Doing some online research and then going for it is liable to get inspectors into a lot of trouble since they can cost $20,000 to replace. Load and dye tests are not considered valid by a lot of very knowledgable people.
This is an inspection about which you really want to be confidant about your training.
-Kent
Old 1/26/06, 11:34 AM
Doug Edwards's Avatar
The Florida law has already been stated and frankly I like it that way. I am not interested in looking through anyone else's "peas and carrots" for a few dollars. Also stated is the level of misinformation and understanding of the process and protocols for an effective inspection. One of the counties we service it is required to pump out and visually inspect the interior of the tank. The dye tests have been debunked by many in the business of septics and state that several hundreds of gallons of water have to be pushed through the system for the dye to reach the drain fields and then reach the surface. Good subject though for discussion (only not at the dinner table) especially for those just entering the profession.
Old 1/26/06, 12:16 PM
rwand1 rwand1 is offline
In Ontario you have to be licenced to inspect wells and septics. And you have to licenced to work on or install same.
Fwiw in my area the minimum flow test results that are acceptable are 3-4 gallons per minute.
I have little faith in dye tests. Purchasers should endeavour to ask the vendor as to the status of the septic, when it was last pumped, tile field, et ceteras. If there are several occupants in the house the septic should be pumped more often. There are many things that can contribute to premature failure, ranging from installation, age, location, soil conditions, load, what is going in is anyones guess, grading, et ceteras.
In these case many of the components are buried, just because there are no visible clues on the surface is no assurance things are correct either. The system could be functioning normally during test and a month later there are problems. I always recommend my clients entertain the services of the previous honey wagon operator because they have the best historical evidence, and may even know who installed the system.
Water testing should be conducted before closing and a clean bacteria test should be the result. After that puchasers should take 3-4 more samples over the year to ensure there are no problems (bacteria wise) and establish a baseline.
When I do rural properties if at all possible look at well heads and try and walk the tile field. Although not licenced it is not surprising to find tile bed problems, well issues. At that point the clients are well advised to seek proper assurances that everything is ticky boo. Often it is not, and I am glad that as a generalist I was able to bring it to their attention.
Cheers,
Old 1/26/06, 2:34 PM
twheeler
Guest
Posts: n/a
That would be 3-4 gallons per minute over a span 30 minutes.
Old 1/26/06, 3:42 PM
Actually thats 3-4 gallons per minute for the duration of a hour.
Old 1/26/06, 5:51 PM
twheeler
Guest
Posts: n/a
Sorry..........
Old 2/26/06, 1:35 AM
rblizzard rblizzard is offline
I was asked by Realtor if I was Septic System certified, I told him I was not. He explained there are a lot of septic systems in southern Missouri (lead belt area), suggested I should get the schooling. What is needed to be certified?
Old 3/28/06, 7:48 PM
2-day National Association of Wastewater Transporters (NAWT) training and certification class in Boulder colorado, April 24 & 25. NAWT does these classes all over the country. Listed on their website.
Kent
Old 3/28/06, 10:39 PM
gbeaumont's Avatar
Roy call or email member Dave Bush, he has just gone through the classes, I believe it was 2-3 days
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
New Washington Legislation Submitted gdomagala Legislation, Licensing & Legal Issues for Inspectors 294 2/10/08 1:20 AM
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 5:58 PM
