Any of you provide this service for wells with high bacteria? What do you see as the liability (besides making someone sick or killing them)?
Is it worth the risk? What would you charge if you did it? Would you have a separate contract? “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
I offer the service, but sure don't push it! Its several trips + an additional sample. I typically charge $ 250.00 +-, but try to get out of doing it.
I don't see any huge liability, and in the 50 or so wells I've done, I've never had an issue. I have had to chlorinate a second time to get a good test, and I have learned to check for a K-packer ( sealed bushing near top of well casing ) before dumping chlorine in! John Springstead Home Inspections of USA 1752 N.E. Torch Lake Dr. Central Lake, MI 49622 1-231-544-8016 office 1-231-544-6001 fax www.homeinspectionsusa.us |
What is the signifigance of a K-packer?
Does it provide an opening for the chlorine, or Don't get the chlorine on it? Thanks, Linda |
Hydrogen Peroxide is a better alternative. A six percent solution if you can find it in quantity.
Joe, contact SC DHEC and they can give you the specs they recommend for disinfecting a well. It depends what kind of well, bored or drilled, the static level, and the total depth.
Not hard to do. Just make sure you follow DHEC's guidelines. Larry Schmid First Choice Home Inspection President, SC Chapter of INTERNACHI www.FirstChoiceHomeInspection.com www.YourWarrantyExpired.com |
Larry, my question wasn't HOW to do it, it was "what do you see as the liability" if you do it.
But thanks anyway. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Joe, surely this would fall under the SOP as offering to perform additional services and or repair on a previously inspected property. Plus there is a huge ammount of potential liability connected to the potability of water supply. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
Chlorination of a well is Outside of the SOP and does not fall under the category of Performing Work as the Area is not one that is addressed as an Inspected Element. Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
Your milage may vary, I do see your point though I have always taken the narrowest of views on performing additional work. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
Joe, I have to agree with Gerry. You tested the well in the first place to determine if bacteria was present. It is now part of your home inspection. I think it would now be like anything else found in your inspection. Recommend an expert to correct it, and be willing to do a follow up bacteria sample to check to see if it is corrected.
I don't see any difference between this and anything else you find that you might be able to fix for them. Just my opinion. As far as liability, the lab should be the one stating the water is free from bacteria, so that should cover you on taking the tests. Larry Schmid First Choice Home Inspection President, SC Chapter of INTERNACHI www.FirstChoiceHomeInspection.com www.YourWarrantyExpired.com |
Collecting a water sample is not part of a Home Inspection. It can not arguably be made as included if not provided by the IOA. Contracted Ancillary services (Septic, Radon, WDI, etc...) should be provided independent of the Inspection with separate Contracts specifying their own terms and conditions. Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
I don't see the problem with taking a well sample. Some have indicated that this is a conflict, but I don't see it and will continue to do so as a service when asked (I live in a rural area and there is a demand for this). It is very common for home inspectors in this part of the country to take well samples.
But, after reading the comments I don't think I'll do the chlorination part of it. I'll leave that to others and then offer to re-test if they want that done. Thanks to all. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
When you performed the service of Drawing Water samples....were they contracted under the IOA or were they contracted under a separate contractual agreement providing the Ancillary Service? My assumption is also that your Company was properly Incorporated as a separate business entity ..... Correct? Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
| Need advice from the pros, should I be a Home Inspector? | Rick Andrew | General Inspection Discussion | 7 | 1/1/07 4:12 PM |
| legislation pros and cons | chorne | Legislation, Licensing & Legal Issues for Inspectors | 313 | 12/25/06 10:38 AM |
| Moisture Meter. Pros and cons? | dbucknavich | General Inspection Discussion | 3 | 3/17/06 7:54 AM |
