Old 8/10/11, 6:18 PM
John R. Fordyce's Avatar
John R. Fordyce John R. Fordyce is offline
Default Well Flow Testing Meter
Anyone know the best digital meter for doing well flow testing? I'm looking for one that you can hook up to the pressure tank and as water passes through...it counts the gallons. I've found quite a few online....just looking here to see what brands or models inspectors find that works the best....?
Thanks for all the help.
John R Fordyce
Safe-Buy Home Inspection
Keystone Inspection & Testing Services
NACHI #06051992
<< Home Inspector Marketing Map - Marketing Madness for Home Inspectors >>
Need a home inspection in Georgia? Check out InterNACHI's listing of Georgia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/11/11, 4:18 AM
Peter C. Russell's Avatar
Default Re: Well Flow Testing Meter
John,
Here's the one I use. It's not digital but works well, sorry no pun intended.
http://www.professionalequipment.com...essure-gauges/
Russell Inspection Services
New Hampshire state license # 57
Level I Thermographer, ITC
Certified Building Science Thermographer, ITC
Certified Building Analyst, BPI
Certified Commercial Inspector, ITA
Certified Septic Evaluator, GSDI #148
www.newenglandthermalimaging.com
www.russellinspectionservices.com
www.nhsepticinspection.com
Old 8/11/11, 6:58 AM
Wayne B. Wilson's Avatar
Got the same one as Peter works well for 4 years
Wayne Wilson
East TN Home Inspections LLC
865-256-1490
Old 8/11/11, 8:02 PM
Originally Posted by prussell View Post
John,
I ordered one from here: http://www.urbanfarmerstore.com/ and including shipping it was about 1/3 the price of the one from PE. I don't see it on the site after a quick look but it may be worth a call or an email. I've had mine for 4-6 years. It is made well and works well.
Larry Kage, CMI
231 929 3525
Old 8/11/11, 8:41 PM
Hey guys, I would like to ask a stupid question since I don't do well testing. Fancy gauges and what not, doesn't that just prove how many gallons of water the well pump can put out?
Doesn't this not really tell you how many gallons the well can really put out?
Without the actual draw down test, isn't this a false indicator of what the flow test is all about?
Isn,t the capacity of the pump and the supply piping determine the amount of gallons you will get?
What is the prognosis of this. The well only produces 4 gpm? Isn't the pump size and the pipe size the problem? And not the well?
Just saying.
Old 8/11/11, 9:07 PM
James E. Braun, CMI's Avatar
Yes Marcel, there is a difference between a flow test and a yield test.
Braun Inspection Consultants
Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
Old 8/12/11, 1:07 AM
Darren Tews, P.E. Darren Tews, P.E. is offline
I do ground water allocation and treatment work. Here's a quick primer on water well jargon:
Dependable or safe yield - this is the maintainable flow from the source available for future conditions, including a drought, that (in my state) the master driller calculates and puts on the well permit. A master driller will proof the well with his own equipment to test flow and drawdown, and come up with the dependable yield.
Well allocation rate - if you're in a sensitive area, your state may regulate how much water you can legally take out of the ground.
Pump capacity - this is the number you get off the pump curve for the installed equipment.
Required capacity - this is the number that the state or local jurisdiction says you need to be able to pump in order to provide sufficient drinking water for the application (mobile home, office building, nursing home, etc).
Well test capacity - this is supposed to be the number that the system produces once everything is piped in. There exists a problem, though. Most plumbers/drillers only leave a 3/4 spigot to test for flow, usually through a garden hose. That's ok for a residential well, but for a mobile home park or golf course, that's not good enough. The flow test should be designed for the size of the main and required flow in mind. In my state, PE's have to prepare the test cards, per NJAC 7-10. It's not always a 3/4 inch test outlet, and it's not always the full main diameter.
Also, in your report, be careful not to use the word "certify" when it comes to well water flow rates.
Licensed Engineer (NJ)
Licensed Home Inspector
Oak Ridge Engineering
Old 8/12/11, 6:15 AM
I just state what it produced , I never state how much is available. Loan companies basically want to know if it is working. Most drilled wells here have a state number for the record of the well ,
Wayne Wilson
865-256-1490
Old 8/12/11, 9:29 AM
John,
This device doesn't count the total number of gallons produced ... correct? You basically average the flow and multiply by the time conducted. I'm looking for a device that counts the number of gallons dispensed.
Thanks for your help. Lots of good answers here.
John R Fordyce
NACHI #06051992
Old 8/15/11, 2:11 PM
Nick Gromicko's Avatar
Watch this: http://www.nachi.org/well-meter.htm
Find a Home Inspector
Old 8/16/11, 10:26 PM
Lawrence W. Losciale's Avatar
Lawrence W. Losciale Lawrence W. Losciale is offline
John,
A guage such as this is only mesuring the flow at the spacific out let you test. Also if some one turns on any other water at the time you'll get a false reading. Every bend in the pipe reduces the flow due to friction. So you get a spacific flow at the well head (if there's an out let there) then you go to the house and every hose bib will give a differant reading. So what does this tell you. I don't see the usefulness of this test, turn on the bath room fuacet and shower then flush the toilet, you'll learn more that way.
Old 8/17/11, 12:07 AM
Watch this: http://www.nachi.org/well-meter.htm It explains why not to just flush toilets.
Old 8/18/11, 10:00 PM
Watched it and I still think it needs to be done as Darren explained it to get meaningfull results.
Old 8/18/11, 11:33 PM
Oh, I was looking at the meter as a marketing and business success tool, not a flow meter.
Old 8/21/11, 12:13 PM
Always thinking!
Mold Inspectors in Coeur d’Alene, ID 83815 rspriggs Ancillary Inspection Services & Additional Topics 15 1/3/12 1:14 PM
Water meter flow needle spinning back & forth jmathy Plumbing Inspections 5 2/19/11 7:53 PM
bbbb mcyr Structural Inspections 1 8/19/07 10:26 PM
