Old 5/23/07, 10:20 PM
etrippe etrippe is offline
Default well line to house
I'm drawing a blank. (it is late) What is the proper term for the black plastic line that typ. runs from the well to inside the house?
Old 5/23/07, 10:56 PM
Default Re: well line to house
Hello, southern Michigan...well lateral pipe works for me.
Larry Kage, CMI
231 929 3525
Old 5/23/07, 11:11 PM
jbreazeale jbreazeale is offline
Please Note: jbreazeale is a non-member guest and is in no way affiliated with InterNACHI or its members.
It's usually just referred to as black service pipe.
Old 5/24/07, 6:12 PM
Peter C. Russell's Avatar
I just refer to it as the main water line.
Old 5/24/07, 6:58 PM
HDPE Tubing Service Pipe:
Polyethylene Tubing has many distinct advantages over other types of service pipe. It will not rust, rot or corrode. It has exceptional toughness, excellent resistance to abrasion and will flex repeatedly without damage. CTS Polyethylene Tubing is designed for 200 P.S.I.
IPS Polyethyethylene is offered in four different working pressures 100,125,160, and 200 P.S.I.
Its pressure rating remains unaffected by mild nicks and scratches that may occur during installation. The insulating qualities of Polyethylene help to prevent water from freezing inside the pipe. Should freezing occur, thawing should be done with steam or hot air.
Hope this helps.
Marcel
Old 5/28/07, 2:07 PM
Marcel,
Just wanted to say thanks for all your very informative posts.
Old 5/28/07, 10:09 PM
Joe Farsetta's Avatar
Joe Farsetta Joe Farsetta is offline
ESOP Committee Member
Well service line...
Well service entry pipe...
Well water feed line....
Old 5/29/07, 5:41 PM
Joe, Hope you are fine and well.
Was that a statement or questions?
Just curious.
Marcel
Old 5/30/07, 8:37 AM
Statement. Its all good, as were your suggestions.
Old 5/30/07, 11:03 AM
Hey, Joe!
Good luck with that rediculous situation in NY. Here's hoping they will "forget about it." What a blatant attempt to hijack a whole industry! Geeze!
Thanks again for the course in Memphis. Quickly figuring, I know you couldn't have profited much from it economically, if at all. I've been busier than a one-armed paper hanger, and haven't had a chance to follow up on finding a lab, but I intend to just as soon as things cool off a bit.
Jimmy B.
Meth House? tallen General Inspection Discussion 27 4/6/09 6:21 PM
Foam Insulation ? wrandolph General Inspection Discussion 13 11/18/07 8:30 PM
1 condensate line...... Scott Schultz Inspecting HVAC Systems 2 11/4/07 6:18 AM
Size of supply line aobrien Inspecting HVAC Systems 7 1/2/07 12:40 PM
Chapter Meeting to be Held @ the House of Horrors rbrown1 General Inspection Discussion 3 1/11/06 11:38 AM
