Old 8/5/06, 8:34 AM
dtaylor dtaylor is offline
Default Well pressure tank location
Looking for info on proper placement of well pressure tanks. Apparently when the owner had new tank installed he moved the location of the tank into the utility room in front of the furnace. There is a crawlspace under the home. I will post picture.
Old 8/5/06, 8:54 AM
Default Re: Well pressure tank location
I don't see a pressure tank. I see a water softener but the pic is pretty small.
I don't have a problem with different locations for the PT. Normally it is located nearest the entry point from the well line.
Old 8/5/06, 9:04 AM
rwand1 rwand1 is offline
It should not be a problem.
Old 8/5/06, 9:54 PM
Your responses are appreciated.
Thanks - Don
Old 8/30/06, 10:28 PM
sfigert sfigert is offline
As long as the furnace is still accessableshould be fine there
Old 8/31/06, 6:07 AM
Gary Oleski Gary Oleski is offline
I agree,furnace accessable first.
Gary Oleski Home Inspections
Home Inspections Connecticut
Connecticut . 06610
NACHI04012833
CT#HOI.341
C M I
Reverse Osmosis phinsperger Plumbing Inspections 3 10/30/07 6:28 PM
Septic System Care mlarson Ancillary Inspection Services & Additional Topics 52 8/31/07 10:26 PM
Hydrostatic Pressure Test Edward D. Wend Plumbing Inspections 9 6/5/07 3:58 PM
Hot Water Tank - missing Pressure relief valve? Jan Lombard Plumbing Inspections 31 4/12/07 3:32 PM
air pressure test vs. hydrostatic pressure mcyr Plumbing Inspections 22 7/11/06 6:11 PM
