Old 9/2/08, 1:52 PM
Matt T. Batson Matt T. Batson is offline
Please Note: Matt T. Batson is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Which tools for moisture testing?
Hello, somewhat new inspector here...
I am looking at different instruments for moisture measurement, but there are many choices at many different prices and I would like to spend wisely.
Should I get one that scans across a surface, or one with probes, or both?
I guess with EIFS testing, you need one with a probe at least 3 inches long...
What have your experiences been with this and what would you recommend?
Old 9/2/08, 2:02 PM
Bob Elliott's Avatar
Default Re: Which tools for moisture testing?
You will get many replies , but from watching this topic a long time , I can tell you that Surveymaster Protometer seems to get the best all around reviews.
More than one is needed if you wish to be all encompassing.
Old 9/2/08, 2:44 PM
Andrew MacDonald's Avatar
Andrew MacDonald Andrew MacDonald is offline
Sorry Bob,
Just had to do it... it's Protimeter.
Ben Gromicko says the same thing on his video.
Andrew MacDonald
MacDonaldPropertyInspections.com
InsightThermalDiagnostics.com
ITC/FLIR Certified Building Science Thermographer
ITC/FLIR Certified Level 1 Thermographer
Old 9/2/08, 2:59 PM
Originally Posted by amacdonald
Sorry Bob,
Thanks, just slap the babbling idiot.
Old 9/2/08, 3:07 PM
Greg Bell's Avatar
Greg Bell Greg Bell is offline
Believe it or not I concur with Robert. I have one and it has severed me very well.
Greg Bell
Titusville, Fl
02111507
Serving Central Florida
Old 9/2/08, 9:13 PM
thanks for the advice, looks like I'll be getting that one.
Old 9/2/08, 9:29 PM
James F. McKee's Avatar
myself i use the protimeter aquant...does the job and leaves no holes for customer complaints....jmo....jim
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 9/3/08, 11:24 AM
I was thinking I would need to be able to do both a non-invasive detection of moisture behind the wall AND then do a poke test to see the water content...
What do you think?
Old 9/6/08, 3:28 PM
Douglas Cossar's Avatar
Douglas Cossar Douglas Cossar is offline
Me too
Cheers
Doug Cossar CMI, NHI
Accurate Home Inspection
Services Inc.
Whitby Ontario
www.accuratehomeinspections.ca
05021384
Old 9/6/08, 4:11 PM
jkogel jkogel is offline
Originally Posted by dcossar
Me too
Cheers
Good point. I got the dual purpose SurveyMaster, but never take the cap off the pins.
John Kogel
www.allsafehome.ca
Old 9/6/08, 5:33 PM
bdoles2's Avatar
bdoles2 bdoles2 is offline
Same here...works well!
Old 9/6/08, 9:21 PM
ROBERT W. NEWLAND, JR.'s Avatar
ROBERT W. NEWLAND, JR. ROBERT W. NEWLAND, JR. is online now
I use the Protimeter Mini and it works very well (I'm very discreet with my holes). It's the only one I've ever used so I can't compare with the others.
Robert Newland
Tyrone, GA 30290
NACHI05101290
http://www.CertifiedHI.com
http://www.HomeInspectorTyroneGa.com
Home Inspection Reports Powered by:
HomeGauge eServices
Old 9/6/08, 9:24 PM
ummm, what about this thread?
http://www.nachi.org/forum/f16/stucco-moisture-content-32303/
Sounds kinda like without going into the wall, you cannot get a definitive answer because of many variables...
Just so ya know, stucco is a real common dealeo here in florida.
Old 9/7/08, 10:01 AM
ldapkus ldapkus is offline
I have this along with a GE Protimeter non-invasive meter. The BCam also works well.
Old 9/12/08, 12:12 AM
John Kogel
www.allsafehome.ca
I use both features... a lot. Now that I'm used to having both I wouldn't be happy without both. The pin meters will give fairly accurate readings and the search feature will look behid tile and vinyl.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Moisture in slabs mcyr Structural Inspections 7 8/20/07 7:33 PM
bbbb mcyr Structural Inspections 1 8/19/07 10:26 PM
Is this for real? hgordon IAC2 Indoor Air Forum 47 10/30/06 9:31 PM
Arizona, one day mold cert dbucknavich General Inspection Discussion 4 6/26/06 9:32 PM
