Old 3/14/11, 11:00 PM
Joseph C. Hobbs Joseph C. Hobbs is offline
Default 1/2" Supply Line
I was in a home today and noticed it was running a 1/2" copper supply line right from the meter it did have a 3/4" main from the street. It ran to the water heater both in and out as a 1/2" line and to all fixtures. This house was built in 1944 and is only 720 sq ft single story with a basement and has one bath and a kitchen and laundry hookup. The house had galvinized piping in some areas which was original to the home but my concern is it a problem to run a 1/2" supply line from the meter to the hot water tank then to the fixtures I dont recall seeing this before I thought you needed a 3/4" supply to the hot water bot in and out then 1/2" supply branched off and ran to fixtures. This is in Ohio and my concern is did a homeowner take it upon himself to size the line 1/2" or is this a possible code violation that needs to be checked out.
Need a home inspection in Georgia? Check out InterNACHI's listing of Georgia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/14/11, 11:12 PM
Robert Ernst Robert Ernst is online now
Default Re: 1/2" Supply Line
Since it's a 3/4" supply and not a 1" I believe the 1/2" pipe is fine since you want the branch lines to be smaller than the supply.
Jeffrey R. Jonas's Avatar
Harry probably removed the old galvanized pipe, saw it was only 1/4" ID, and figured he'd upgrade to 1/2".
Old 3/14/11, 11:21 PM
Christopher Currins's Avatar
If there is any galvanized pipe still active that would be my concern.
Christopher Currins
Certified, Licensed
Old 3/15/11, 2:09 AM
David A. Andersen's Avatar
720 sf!!!!!!
I don't think they will be running out of water in that house!
Code violation?! I don't think there is an AHJ in Dayton that was working in 1944 that you could ask.
How about sticking to the HI Standards of Practice and test for functional flow and drainage and leave it at that?
What size feeder tubes are at plumbing fixtures in all houses? 3/8"?
I don't think you have to worry about 1/2 copper.
Also for some added information, a seller is not required to "upgrade" anything in a house being sold. They are only required to repair it if it is broken or disclose that it is busted.
BPI# 5015804
Old 3/15/11, 9:05 AM
Marc-Andre Beauchemin's Avatar
Marc-Andre Beauchemin Marc-Andre Beauchemin is offline
It is done that way so that water systems have balanced hot and cold water pressure.
This means that the water supply which is cold goes solo to the hot water heater tank and from the water heater tank, you have hot and cold piping next to each other on their way to supply fixtures.
The exception is the tankless system which needs only a cold supply.
Old 3/15/11, 9:53 AM
Joe Funderburk, CMI's Avatar
Minimum is 3/4" today, but I wouldn't call it out on that small home unless there was a problem with functional flow.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 3/15/11, 11:17 AM
Roy D. Cooke, Sr's Avatar
Char had a store years ago and the only pipe between the home and store was a one inch .
I put phone, Intercome, and tv cable, and a 1/4 plastic water pipe in it .
In the store I put in a 10 gallon Bladder storage tank .
We ran that for years and never was short of water .
Had a wash room and toilet two sinks and small water heater .
If I had run short of water I would have put in a second Bladder tank
Old 3/16/11, 10:44 PM
Christian F. Mettel Christian F. Mettel is offline
Call out the galvanized pipe. Test for functional flow. If there's not enough pressure, call it out. If there is enough pressure, then 1/2" would seem to be sufficient for the size of the home.
Christian Mettel
Certified Home Inspector
Aurora, Ontario
289-221-4744
iNachi ID#06022187
www.buildingdetective.ca
Aurora Home Inspection
Steel supply line. sfalvey Plumbing Inspections 4 1/28/11 9:11 AM
Condensate drain line scroenne Inspecting HVAC Systems 1 5/5/10 7:07 PM
1 condensate line...... Scott Schultz Inspecting HVAC Systems 2 11/4/07 6:18 AM
Supply Line Question hmcclard Plumbing Inspections 5 10/29/07 10:42 AM
Flexible copper 1/2" gas line to water heater -- how big an issue? fbartlo Plumbing Inspections 30 11/3/06 1:19 PM
