Old 9/24/09, 10:49 PM
Al D. Bolt Al D. Bolt is offline
Default 1" clearance
Does this application still require a 1" clearance from combustibles?
Find an InterNACHI certified Texas Home Inspector (and anywhere else in North America)
Old 9/24/09, 11:30 PM
Joe Funderburk, CMI's Avatar
Default Re: 1" clearance
If that's sheetrock, then it isn't "combustible" and there is no issue. Isn't sheetrock used to provide a fire barrier between the garage and home?
However, if that is a garage, then there is void in the fire barrier. The gap should be protected by a flange to prevent flame entry into the structure above the ceiling.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 9/25/09, 12:32 AM
Brian E. Kelly's Avatar
B Vent manufacturers will disagree and tell that a 1" clearance is required.
Can I install drywall or wall board right up against the gas vent?
No. Drywall and wallboard are considered combustible materials and should not be installed against the vent including the use of this material to close off the hole around the vent. Type B Gas Vent requires a minimum of one-inch clearance to combustibles. This one-inch is a typical clearance for all brands of Type B Vent, but each section of vent pipe is marked with the clearance required by Underwriter Laboratories, so it should be checked
http://www.americanmetalproducts.com...rivent/faq.htm
Old 9/25/09, 11:09 AM
I think the difference is due to the different purposes. One is with performance under the conditions during a fire (where it is considered noncombustible), and another is with performance during exposure to a constant high-heat source (where it is considered combustible).
Correct?
Old 9/25/09, 12:15 PM
rmaday's Avatar
rmaday rmaday is offline
Please Note: rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
I believe it is "combustible" as it will burn.
It is "fire-resistant", not "fire-proof"
Decent article...
http://www.homeadditionplus.com/dryw...ed-Drywall.htm
Old 9/25/09, 7:46 PM
Once again, it has nothing to do with drywall manufacturer, it has to due with what the Manufacturer recommends for the installation of their product. And how the product was tested by whatever agency validates the safety performance of the rpoduct(UL).
The dryall manufacturer can say whatever they want about their product............. They do no make B Vent.
Pyrolysis is also taken into consideration..................................... .....
Old 9/25/09, 7:56 PM
Bob Elliott's Avatar
Anyone know of a single problem caused in not having clearance?
Old 9/25/09, 8:00 PM
Many fires in the north from pipes too close to combustibles. Watch the news this heating season or check with your fire department if need be for verification.
Larry Kage, CMI
231 929 3525
Old 9/25/09, 8:02 PM
Jeffrey Moore Jeffrey Moore is offline
Brian,
Don't you have to have an absence of oxygen to be called pyrolysis?
No, I haven't seen or heard of a problem with a smaller that 1'' clearance but
still call it out.
Jeff Moore
www.quantumhomeinspections.com
Flir (ITC) Level II Thermographer
Mesa, AZ
Old 9/25/09, 10:08 PM
Thanks, but did they blame the drywall clearance?.
Old 9/25/09, 10:21 PM
rbrady's Avatar
rbrady rbrady is offline
Please Note: rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
Here is a picture of drywall in an interior utility closet that didn't 'burn' under pretty much worst case scenario with a flue! I ran into this a few years ago. I think someone made a boo boo when they were re-roofing.
Old 9/25/09, 10:32 PM
Think I need to get a propane torch and see what happens , though I seem to recall a discussion here in the past about materials becoming more flammable over time when exposed to heat .
Old 9/26/09, 11:15 AM
Read all of this and pay particular attention to the last paragraph. Provided Larry's information is correct, drywall is considered non-combustible by 3 national model building codes, I don't care what the b-vent manufacturer's say about it.
http://www.nachi.org/forum/f22/b-ven...34/#post543528
Theodore Roosevelt
Joe Funderburk, CMI
Old 9/26/09, 5:14 PM
Remember to pay attention to whether there is wood behind the drywall within these clearance distance situations...
Larry Kage, CMI
231 929 3525
Old 9/26/09, 5:43 PM
The paper is the combustible it says.
Walking surface and wall clearance dbucknavich Exterior Inspections 9 5/27/08 6:07 AM
Clearance Testing tfarmer Ancillary Inspection Services & Additional Topics 15 2/26/08 5:41 PM
Range Clearance dsmith6 Interior Inspections 18 1/7/07 9:55 PM
Service panel clearance wwarner Electrical Inspections 13 8/12/06 12:07 PM
Siding to Ground Clearance tneumann Exterior Inspections 14 2/8/06 11:48 PM
