I tested 127 degrees temp. at the kitchen sink
is that too high ? What is the exceptable range ? David P-H-I |
yes, it should be below 120 for sure. 100-115 is good for most people.
************************************** Shawn Rowe, CMI HomeFirst Inspection Services, LLC - InfraRed Specialist (Level 1 & Building Science certified) - Code Certified Residential Building Inspector - Certified Master Inspector -- Serving NE Florida, St. Johns, Duval, Flagler, Putnam counties -- |
Shawn,
Be careful at 10 degrees and below. Some one in one of our classes told us that if the water is below 110 degrees, bacteria can grow and possibly cause illness. The following label was taken off a water heater: Temperature Time to Produce 2nd & 3rd Settings Degree Burns on Adult Skin 160°F (71°C) About 1/2 second 150°F (66°C) About 1-1/2 seconds 140°F (60°C) Less than 5 seconds 130°F (54°C) About 30 seconds 120°F (49°C) More than 5 minutes 80°F (27°C) - - - - - - - - - - - - - - - - |
| 130 degree water temperature | dnasser | Plumbing Inspections | 16 | 3/6/07 5:30 PM |
| Need Help On Chimney Liners | Nick Scibetta | Exterior Inspections | 13 | 1/11/06 9:53 PM |
