Old 9/19/08, 8:26 PM
jkogel jkogel is offline
Default Are 2 TPRV's as good as 1?
Yes, I know it's Poly-Butyl, with both copper and silver crimp rings, and there is no 18 " copper stub on the cold supply, no shutoff either. I know there is no conduit on the supply wire, but it's in a cabinet, mobile home. My question is, is it OK to have Two TPR valves? Yes, I know there is no discharge tube on the second valve, but that is not the question.
This was a professional install BTW, hey, we can't all be Einsteins.
John Kogel
www.allsafehome.ca
Old 9/19/08, 8:53 PM
Greg Bell's Avatar
Greg Bell Greg Bell is offline
Default Re: Are 2 TPRV's as good as 1?
You are going to find poly in most mobile homes. Poly that is used in mobile homes is not eligible for replacement. Visit this site for more info.
www.pbpipe.com
Greg Bell
Titusville, Fl
02111507
Serving Central Florida
Old 9/19/08, 9:00 PM
John Kogel
www.allsafehome.ca
John, my answer would be no, but I am not a plumbing expert by far.
I would suggest to anyone in this business to watch this Nachi TV segment.
Very well put together by Kenton Shepard and Staff.
http://www.nachi.tv/ppv/8
Hope this helps.
Marcel
Old 9/19/08, 9:02 PM
Bob Elliott's Avatar
John Kogel
www.allsafehome.ca
Just to play this fantasy
If there were 10 TPR valves it would not change the amount of pressure it takes for them to blow.
Yes they would have slight variation in trigger, and one would blow before the others knew what was happening.
Therefore in theory , it would not matter how many TPR valves are attached.
There has got to be a joke in there somewhere.
Old 9/20/08, 12:03 AM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
I thought for a long time Bob and although it seems like a perfect spot for a joke I couldn't come up with one. I can't think of one reason to have even 2 TPRV's in line. The first one (closest to the WH) will most like pop first.
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Old 9/20/08, 1:10 AM
Jeffrey R. Pope's Avatar
There is no problem with having multiple TPR's on a tank, as long as at least one of them is installed properly.
The valve on top appears to be mounted on top of an extension (another fitting) which is improper. A TPR valve is required to be a specific depth within the tank.
I can't see how/where the side valve is mounted, so I can't comment other than to say it's missing its discharge piping.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 9/20/08, 2:34 AM
Gerry Pallotta's Avatar
Gerry Pallotta Gerry Pallotta is offline
Send a message via Yahoo to gpallotta
The top tprv is usually seen on a storage tank to prevent scalding water from entering the system. The thought here may be the above purpose or to hopefully get any water that discharges from the system to the exterior of the home (assuming that is where the discharge pipe is going) or both.
"The valve on top appears to be mounted on top of an extension (another fitting) which is improper. A TPR valve is required to be a specific depth within the tank."
For a storage tank senario it is set up properly. Personally I have never seen or heard of it on a water tank. You'd have to check with your local code to see if this is accepable.At the moment I cannot find anything on it.
Old 9/20/08, 3:28 AM
Found something according to Watts.
http://www.watts.com/pro/divisions/w...upport_t-p.asp
hope this helps.
Old 9/21/08, 12:22 AM
Thanks, Jeff. The second valve is down on the right side, mounted the proper depth and therefore would probably blow first if the temperature got too high. The top one would discharge thru the hole in the floor, mobile home, if it ever blew, still possible from a pressure buildup I think.
hope this helps. Gerry
Thank you, Gerry. Correct depth = 6" into the tank.
Old 9/21/08, 12:31 AM
Thank you, Gerry. The top valve may well be the extended type designed for this type of installation.
Good info about multimeters and safety badair Electrical Inspections 8 7/29/08 10:35 PM
Deere John: It's Been A Good Ride jburkeson1 Miscellaneous Discussion for Inspectors 1 7/19/08 12:29 PM
OAHI Out Of Control - Bylaws Breached - Documented Proof rwand1 Canadian Inspectors 423 2/25/08 6:20 PM
Grounding -V- Bonding Article (Good Read) pdoane Electrical Inspections 0 10/12/06 4:31 PM
