Old 11/20/06, 11:36 PM
dthomas2 dthomas2 is offline
Please Note: dthomas2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default 45 degree slope of 3" waste pipe?
Sorry, No picture.
Twice this last week I saw horizontal 3" waste pipe dropped a foot or two over three to five feet span (with the use of 45 degree splices.) I have seen nothing in my library that says "don't do it this way ..." Although, because my material makes no exception to the to 1/4 - 1/8" rule I noted in these reports that elevation changes accomplished in this way will eventually cause problems and should be changed to 90 degree transitions. Am I correct?
Old 11/20/06, 11:43 PM
Dale Duffy's Avatar
Default Re: 45 degree slope of 3" waste pipe?
Dennis, if you ever had to clean the line 45's would allow a snake through without dismantling.
Old 11/20/06, 11:50 PM
Jeffrey R. Pope's Avatar
90's are more likely to cause problems in drain line than 45's. . .
Neither is improper.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 11/21/06, 12:13 AM
ouch!
Darrell B. Hadler's Avatar
Darrell B. Hadler Darrell B. Hadler is offline
Don't see how this could cause a problem. I would far sooner see a couple of 45's used in the manner you stated, than a 90. Better flow with lest restriction, and as mentioned in previous posts...much easier to snake/auger.
Darrell Hadler CMI
Five Star Home Inspections
Medicine Hat, AB. Canada
NACHI# 04111082 Cell phone# (403)502-3593
Inspected once . . . inspected right!
Old 11/21/06, 12:25 AM
jschulte jschulte is offline
Please Note: jschulte is a non-member guest and is in no way affiliated with InterNACHI or its members.
I think the problem generally comes from the fact that if you have too much slope, solids will build because the liquids drain too fast. However, if it's over a short span, I do not think it will be a problem, especially if it drains into a vertical line. I would consider a three to five foot span a short distance.
Just my opinion, though, I haven't spent much time in a drain line to see it happen.
Old 11/21/06, 1:14 AM
Thanks guys.
Right now I am googling to see if I can find a definitive statement. The problem is that the charts and write-ups I use as reference do not sight exception to the 90 degree rule. Since I fear overlooking a problem with a seemingly correct situation I would like to see a research related report - so I am trying to find one.
Old 11/21/06, 8:50 AM
ckratzer ckratzer is offline
Please Note: ckratzer is a non-member guest and is in no way affiliated with InterNACHI or its members.
I'd be guessing Dale has done the research .
Hands -on experiance. Thats what I'm talking about .
Old 11/21/06, 5:56 PM
lcapaul's Avatar
lcapaul lcapaul is offline
Please Note: lcapaul is a non-member guest and is in no way affiliated with InterNACHI or its members.
Originally Posted by dthomas2
Thanks guys.
Dennis,
Do you have the Code Check 4th Edition? On page 14 under drainage/changes of direction it states:
Vert to horiz or horiz to horiz through wye branches or 45 degree wy branches of fittings of equal sweep IRC 3005.1 UPC 706.3,4
Hope that helps.
Old 11/21/06, 6:07 PM
lcapaul's Avatar
Originally Posted by lcapaul
Dennis,
Do you have the Dode Check 4th Edition? On page 14 under drainage/changes of direction it states:
Hope that helps.
Dennis,
I knew I'd read it some where, in Howard Massey's Plumbers Handbook on page 25: Verticle offset in Drainage Pipes,,,,,"You can consider as straight any verticle stack with an offset of 45 degrees or less. Size it as a straight vertical stack....."
Just make sure the fittlings don't reduce the diameter of the pipe or have any ridges that may cause an obstruction.
Old 11/21/06, 6:39 PM
scosta's Avatar
scosta scosta is offline
Please Note: scosta is a non-member guest and is in no way affiliated with InterNACHI or its members.
This is what I have.
Old 11/21/06, 7:12 PM
lcapaul's Avatar
UPC 706.4
706.4 Vertical drainage lines connecting with
horizontal drainage lines shall enter through fortyfive
(45) degree (0.79 rad) wye branches, combination
wye and one-eighth (1/8 bend branches, or other
approved fittings of equivalent sweep. Sixty (60)
degree (1.05 rad) branches or offsets may be used
only when installed in a true vertical position.
SANITARY DRAINAGE
113
Old 11/21/06, 11:23 PM
UPC 706.4
SANITARY DRAINAGE
113
Lewis,
Thanks for the effort. Does the UPC distinguish between a Solid waste drain and a sink/basin drain? Is the "706.4" referring to a solid waste drain?
Old 11/21/06, 11:27 PM
Steve,
I have this picture too and is why I have a problem with contray statements. I did not find an exception with my google search but for some reason I could not get to the UPC - except to purchase. I may go the Library of Congress.
Thanks for the help.
Old 11/22/06, 12:43 AM
lcapaul's Avatar
Dennis,
Here's a link to chapter 7 of the UPC
http://www.iapmo.org/common/ROP2004/...eprint/ch7.pdf
(If you want to see other chapters just change ch7 to whatever number you want.
Where are our plumbing guru's? I'm not sure about the verticle drop in the horizontal drain lines using 45's, but I think your statement "I noted in these reports that elevation changes accomplished in this way will eventually cause problems and should be changed to 90 degree transitions." was pretty good, although I would have used "May" instead of "will" cause problems and wouldn't have mentioned changing the fitting to 90 degree, I'd leave that up to a plumber
Do you put polybutylene in the Summary? jfunderburk Plumbing Inspections 41 4/5/12 6:43 AM
Help - Polybutylene Pipes Rick G Plumbing Inspections 39 2/12/09 8:16 AM
Identify ABS defective pipe mcyr Plumbing Inspections 6 1/29/09 6:39 PM
orangeburg waste pipe bking Plumbing Inspections 5 10/24/07 5:46 PM
main waste pipe bking Plumbing Inspections 1 5/17/06 9:14 PM
