Anyone ever see this type.
Plate says 327 gallon per hour recovery. Will that be enough (units have spa tubs) ? ![]()
| Find an InterNACHI certified Massachusetts Home Inspector (and anywhere else in North America) |
I haven't personally seen one of these, but it appears to be a Rheem high-capacity commercial unit. To me it seems to be almost a "tankless" style heater and tank combination with recirculation pump. At 360,000 btu/hr. input it will heat a lot of water fast. According the the Rheem table it will raise 75 gallons of water 100 deg. in 5 minutes. By comparison, their residential tankless heater is only rated at 180,000 bth/hr and regular residential gas heaters are only 40-60,000 btu/hr. So, without trying to out-engineer the architect that likely selected the unit, I would probably not discredit it for that service.
http://74.6.239.67/search/cache?ei=U...icp=1&.intl=us Frank P. Newman Emerald City Inspections, LLC Dublin, GA |
They may need a clipboard installed in the hall with the designated shower times for each unit.
Well, if you take the 327 Gallons per hour at its face value and do some simple math, you come up with a problem.
Lets say half of the 28 units all run their tub at the same time. At 5gpm (rough average spigot rate), times 14 units, times 5 minutes: you get 350gallons used. That leaves nothing for the tooth brushing, shaving, dishwashers, wash machines, etc. Now granted nobody runs a bath that is 100% hot valve only, but it's not difficult to visualize a potential issue. Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
Mark,
Do you really brush your teeth with warm water? That's a very high output unit. Is it enough for 28 units? I don't know but assuming 1/2 filling the tub at the same time is a bit high unless they all work the same shift at the same place. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Here's something for individual calcs...
http://www.consumerreports.org/cro/a...heaters-ov.htm |
I am guessing it is fine but Suggested Plumber do sizing .
New rehab with 2002 unit. Note serial number of 0202 |
Thanks, Mike
**edited, LOL I didn't bother to fill out the form... |
Turns out that one was Aussie only...I bet they have a US version though.
"You know what they call a Quarter Pounder in Amsterdam?"
"Royale w/ cheese." ...and do you know why that is? |
Thats right the metric system.... |
| flammable vapor ignition resistant | dbaucum | General Inspection Discussion | 35 | 2/19/08 1:42 PM |
| Hot Water Heater | djohnson6 | Plumbing Inspections | 12 | 12/28/06 9:18 PM |
| Need Help On Chimney Liners | Nick Scibetta | Exterior Inspections | 13 | 1/11/06 9:53 PM |
