I saw this in a one bedroom condo on the ground floor but could not trace it.
Please help. |
Drain line for the dishwasher?????????????????????
sparksnmore is a non-member guest and is in no way affiliated with InterNACHI or its members.
Condensate drain from air-conditioner ?
The angle suggests it's supplying something. Is there a floor drain that is keeping the water seal fresh?
tom |
Without going into much detail about the above responses, I would say first, Probably not a supply line, and if it is a condensate drain line then it would be configured to be an S trap. Is there a water softener?
Mike,
Welcome, an understatement would be "wrong" DW = wrong Condensate = wrong Anything else = wrong Consult a qualified pluber to correct this installation, as a potential for possible cross contamination exists ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
Where is the water heater - on the other side of that wall perhaps?
Randy |
Ian Gills is a non-member guest and is in no way affiliated with InterNACHI or its members.
Must be a feed to the icemaker. Mmmmmmmm tasty.
My concern would also be cross contamination..If you can't trace it..refer to plumber..
jtaylor5 is a non-member guest and is in no way affiliated with InterNACHI or its members.
I agree with wrong.
