Old 1/24/08, 1:00 AM
Andrew Cox Andrew Cox is offline
Default What is this for?
This house was built 10 years ago, and the original owner was a plumber - did the house plumbing himself.
Have you ever seen this? It's a plumbing distribution panel. Hot and Cold lines come in, and it branches off to all the fixtures in the house, with all the fixture shutoffs at this one spot.
I was pretty impressed...not that it takes much!
Andy Cox
http://www.CoxInspections.com
Kissimmee, FL
You’re Your Own Job Security.
Old 1/24/08, 1:08 AM
Stephen W. Stanczyk's Avatar
Default Re: What is this for?
A very common PEX distribution panel. I see these a lot during draw inspections. Builders either use them in all their homes, or in none of them depending on which supplier they use.
Stephen Stanczyk
Old 1/24/08, 1:09 AM
Marc D. Shunk's Avatar
Banned
That's a Manabloc. An older one, from the looks of it. That's quickly becoming the standard way to pipe up a new home in my area. Pretty slick. Really no pressure drop at the fixtures when someone flushes a toilet, etc.
Old 1/24/08, 1:33 AM
Bob Elliott's Avatar
That would depend on the supply.
Anyway Andrew , how big was that house with so many fixtures.
I notice there are eight using cold only so I imagine the outside water supply to the lawn is there also.
Still seems like alot for a studio apartment.
Old 1/24/08, 2:01 AM
Brian E. Kelly's Avatar
That is so when those polybutylene water lines break, you can isolate them.
Old 1/24/08, 2:07 AM
Ha.. Here in Chicago we do not have that problem with our wonderful galvinized.
Old 1/24/08, 8:12 AM
Michael Larson's Avatar
In case you missed the intent of Mr. Kelly's comedic remarks, did you notice any markings on the pipe such as PB2110?
edited: to corrrect typo
Old 1/24/08, 8:34 AM
Mark A. Timpani, CMI's Avatar
Mark A. Timpani, CMI Mark A. Timpani, CMI is offline
Run, that is poly....
"Be Proud of Your Home, Go With Pride!"
'Not just a Home Inspection, but an Education'
Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties.
Old 1/24/08, 8:55 AM
No, could not see markings at all. It is black piping to this panel, but not from it. And it's 3688 Sq Ft, 5BR/ 4 baths. This is to be a vacation home.
The supply to this panel is buried in the wall, could only see 1-2" at this end. And yes, I was amazed at the pressure available at all fixtures.
How should I report this - as poly piping?
Andy Cox
Kissimmee, FL
Old 1/24/08, 9:22 AM
Should have said PB2110 earlier.
See this thread for some verbage on the issue
Old 1/24/08, 1:14 PM
Since we really do not see pex or poly that blew right over my head.
Old 1/24/08, 5:17 PM
Jeffrey R. Pope's Avatar
Yep, PB, which (as we all know) is no good.
The manifold is a common install in new construction, typically seen with PEX or PE.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
I've not seen it either, but one other time. Thanks for all the help.
Andy Cox
Kissimmee, FL
Old 1/24/08, 6:53 PM
reminds me of zoned heat
