Anybody know what this is? Looks like a bypass on cold water supply to hot water tank. One line has vacuum break going into drain stand pipe. Im not sure why it was done like this? Your suggestions are greatly appreciated. Thank you.
I'm not sure but I think it's a pressure release valve. Not the TPR but one of another type.
Flow through trap primer
badair ADAIR INSPECTION 972-487-5634 Residential-Commercial-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes...accept the good |
Looks like some sort of air bleed valve to me. It's hard to tell from the picture though. Something similar to what is usually installed on hydronic heating systems. If that's the case, it looks like it's installed upside down.
It's hard to say without actually being there and getting a true 360 degree view. Scott Gilligan Philadelphia Mold Inspections Philadelphia Home Inspections Philadelphia Commercial Inspections Philadelphia Licensed Home Inspector #34206 President The Greater Philadelphia Chapter of InterNACHI http://pa.nachi.org/greaterphiladelphia Philadelphia, Pennsylvania real estate professionals on ActiveRain.com |
what is it for?
"Be Proud of Your Home, Go With Pride!" 'Not just a Home Inspection, but an Education' Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties. |
Another method is to have the small supply pipe connected to a regularly used faucet. Each time the faucet is used, a small quantity of water is delivered to the trap. I prefer the second method over the first as I have seen many of the drip type now not funtioning either due to corrsion, or possibly dirt, blocking the drip mechanism. Last edited by Brian A. MacNeish; 7/24/08 at 1:07 PM.. |
No matter how filtered or softened your water is eventually the minerals that escape that process will clog the drip. I agree Brian.
In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
