I saw this installed on a water heater. First thought is it was a curculating pump. Something does not look normal. any ideas?
Yes it is a circulating pump.
"Never underestimate the difficulty of changing false beliefs by facts." |
I have seen people use Hot water heaters as boilers and someone told me a couple weeks ago that they seen one that had a coil in it with fittings for BB hot water. I have never seen one though.
Rick Kie |
appears to be a recirculation pump. But remember there are certain ways these are to be installed...You can't just put them in any old way...look a tthe make and then research it if possible. The wiring sure as heaven doesn't look normal.
HW circulating pump. No insulating unions and very clean joints, surprize, surprize.
Those that have never made a mistake have never done anything. Jack Gilleland Home Inspection Services Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
| Display Modes | |
