Old 10/4/06, 10:28 PM
Kenneth Blair Kenneth Blair is offline
Default What is this
This was hang from and up under cast iron drains. What is it and what caused it?
Old 10/5/06, 12:54 AM
jjones2's Avatar
jjones2 jjones2 is offline
Send a message via MSN to jjones2
Default Re: What is this
not sure about white stuff.Is it hard or soft ?looks like water logged expanding foam.
pipe looks like galvanized drain pipe to me!
Old 10/5/06, 1:10 AM
Dale Duffy's Avatar
Looks like crystallized drain cleaner, like Drano.
Could just be real hard water mineral deposits from the obvious leak, but if you add drain cleaner to hard water and let it slowly leak, you'll have stalagmites.
Old 10/5/06, 9:35 AM
This drain pipe is galvanized which connects to cast iron just below this pic. The white stuff is hard and there was evidence of a past leak.
Old 10/5/06, 9:42 AM
thejnicki's Avatar
thejnicki thejnicki is offline
Looks like the Mercer Caverns to me..LOL
Old 10/5/06, 10:54 AM
John J. Passailaigue, Jr.'s Avatar
John J. Passailaigue, Jr. John J. Passailaigue, Jr. is offline
Send a message via AIM to jpassailaigue
I agree with Mr. Duffy! I have seen this before and always tell my clients that if the home has cast iron plumbing pipes, not to use draino or liquid plumber. Those things eat cast iron pipes up and then leak in the crawl space.
John J. Passailaigue Jr.
NACHI05062580
Auburn Home Inspection
Auburn, Alabama
WAR EAGLE!
Old 10/5/06, 11:31 AM
David A. Andersen's Avatar
Looks like your inspecting the Flintstones home!
Old 10/5/06, 1:15 PM
nwagner's Avatar
nwagner nwagner is offline
Was this a house or a cave?
Old 10/5/06, 6:14 PM
twasion twasion is offline
Please Note: twasion is a non-member guest and is in no way affiliated with InterNACHI or its members.
Stlagtights and stlagmites. This is probably a leak and it is heavy water (not as in nuclear: but un-softened). This will happen with other drain materials too such as PVC or ABS. Was this a shower pan? Looked like it.
