Old 3/15/08, 8:52 PM
Joseph Hagarty,  CMI's Avatar
Default ABS and PVC connections.
install is ok because general purpose cement was used.....
(Sawzalls are an amazing tool.....)
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 3/15/08, 9:05 PM
James F. McKee's Avatar
Default Re: ABS and PVC connections.
was that a question or a statement Joseph ???....nice treatment of floor joists in any way....
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 3/16/08, 1:35 AM
Dale Duffy's Avatar
From the IRC: if you use the IRC..........floor joist is fine.....
P3003.2 Prohibited joints.
Running threads and bands shall not be used in the drainage system. Drainage and vent piping shall not be drilled, tapped, burned or welded.
The following types of joints and connections shall be prohibited:
1. Cement or concrete.
2. Mastic or hot-pour bituminous joints.
3. Joints made with fittings not approved for the specific installation.
4. Joints between different diameter pipes made with elastomeric rolling O-rings.
5. Solvent-cement joints between different types of plastic pipe.
