Old 8/27/11, 3:51 PM
Joe Funderburk, CMI's Avatar
Question ABS to Cast Iron: Any plumbers online?
Shouldn't this be a mechanical connection?
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Need a home inspection in North Dakota? Check out InterNACHI's listing of North Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/27/11, 4:15 PM
Default Re: ABS to Cast Iron
It appears they might have used one of these meant for that application.
http://plumbing.hardwarestore.com/52...er-240648.aspx
Old 8/27/11, 4:19 PM
Jeffrey R. Jonas's Avatar
That would be my guess also, as there are no signs of leakage in the pic.
Old 8/27/11, 4:25 PM
2009 IRC P3003.18 Joints between different materials.
Joints between
different piping materials shall be made with a mechanical
joint of the compression or mechanical-sealing type conforming
to ASTM C 1173, ASTM C 1460 or ASTM C 1461. Connectors
and adapters shall be approved for the application and
such joints shall have an elastomeric seal conforming toASTM
C 425, ASTM C 443, ASTM C 564, ASTM C 1440, ASTM D
1869, ASTM F 477, CSA A257.3M or CSA B602, or as
required in Sections P3003.18.1 through P3003.18.6. Joints
between glass pipe and other types of materials shall be made
with adapters having a TFE seal. Joints shall be installed in
accordance with the manufacturer’s installation instructions.
Theodore Roosevelt
Joe Funderburk, CMI
Old 8/27/11, 4:35 PM
Joints between
Well, did it?
Old 8/27/11, 4:41 PM
Joints between
Jeffery, to me that means a "rubber" type connector with clamps.
Theodore Roosevelt
Joe Funderburk, CMI
Old 8/27/11, 4:47 PM
I was thinking two of these would work well:
http://www.fernco.com/
Larry Kage, CMI
231 929 3525
Old 8/27/11, 4:55 PM
In my opinion, you would be partially wrong...
A rubber connector is not the same thing as an elastomeric seal. An elastomeric seal is a pliable/rubberized sealant when cured, (as opposed to oakum), or a manufactured pliable seal (such as an o-ring). Most likely this was installed with a pourable sealant, but you were there. What did you observe?
You also need to break the paragraph down...
Joints between different piping materials shall be made with a mechanical
Old 8/27/11, 5:00 PM
Originally Posted by jjonas View Post
...you were there. What did you observe?
Thanks for the explanation. Here's what I saw.
Theodore Roosevelt
Joe Funderburk, CMI
Old 8/27/11, 5:09 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
Default Re: ABS to Cast Iron: Any plumbers online?
Joe:
Why do you get all the fun inspections. I can't even crawl under many of the inspections in my area. No fare !!!!
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 8/27/11, 5:13 PM
Originally Posted by kwood View Post
Joe:
Crawling in a wet, 24" high crawl space in 90 degree (F) heat and 90% humidity with mosquitoes buzzing around your ears ain't fun!
Theodore Roosevelt
Joe Funderburk, CMI
Old 8/27/11, 5:18 PM
Attachment 47738
Hmmm...
Impossible to tell in the pic, but if I had to guess, I would say oakum, or (gasp) caulk, was used. Did you attempt to 'feel' the seal/sealent? If so was it 'rubbery'? I guess technically, (if it meets the listed standards) silicone would be an elastomeric sealant.
Old 8/27/11, 5:24 PM
Hmmm...
Didn't touch it. I guess I'll not say anything about it this time. I believe this is the 1st time in 6 years I've seen this. Maybe when I see another one I'll be better informed.
Theodore Roosevelt
Joe Funderburk, CMI
Old 8/27/11, 5:30 PM
See, learn something new every day!
Old 8/27/11, 6:40 PM
Barry Adair's Avatar
i'd at least mention uncertain/undetermined dissimilar material connection
that way when it leaks or fails the day after closing...
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
cast iron piping ghelder General Inspection Discussion 4 6/24/11 12:27 AM
Cast iron Galaxy boiler age? smcrae Inspecting HVAC Systems 1 6/20/11 10:51 AM
Cast Iron Question cmainka Plumbing Inspections 1 1/27/11 9:05 PM
PVC to Cast Iron - No flexible connection mmixson Plumbing Inspections 1 7/29/09 1:29 PM
Cast Iron Waste Stack & Homeowners Insurance jskrypka Plumbing Inspections 5 5/2/07 1:36 PM
