Hi all I AN doing my mock H.I and i noticed that the tub faucet is on an outside wall and there is no access panel to get to the plumbing should i write this up thanks alan
"Write it up"?? "Call it out"?? I don't quite understand what that all means. HIs don't "write up" anything--that sounds so negative. We simply report what we see.
You saw tub faucet on the outside wall with no access panel--report it...along with an explanation of why you thought it worth the mention. Let the client decide what to do with the information. We simply report...that's all we are--reporters. Keeps us out of trouble that way. If you were to explain to the client that you "wrote it up", the client could misinterpret that as meaning a bad thing. Keep it on the positive side. "not just an inspection, but an education" www.homesweethomecincinnati.com Democracy is two wolves and a lamb. Liberty is a well-armed lamb. B. Franklin |
There's no Code that states that plumbing fixtures must have an access panel. It's more like a convenience panel to me.
I don't write them up. If it's there GREAT, if not...OH WELL. |
Normal tubs require no access. Jaccuzzi's do
twasion is a non-member guest and is in no way affiliated with InterNACHI or its members.
Where I use to plumb it was required to have an access panel for the tub though one was seldom installed and it was not enforced. As a plumber it made my job much easier than cutting a hole in the drywall to access it especially when it was an emergency.
| Panel access | nbhi | Electrical Inspections | 11 | 2/4/07 10:05 PM |
