Old 5/6/08, 5:55 AM
nbhi's Avatar
nbhi nbhi is offline
Default Accordion
What verbage would be used for this contruction? I know this application is more prone for blockage.
Attachment 20940
"I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison
www.newbeginningshomeinspection.com
Old 5/6/08, 6:10 AM
Barry Adair's Avatar
Default Re: Accordion
What verbiage would you, as a first time buyer, want to read or think appropriate? and then also convey the issue/material in question to the professional that makes the repair.
Use your own words, post it here and let the seasoned guys reply.
Russel had a 1000 Narratives list going, try the search on our MB
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 5/6/08, 1:38 PM
Attachment 20940
Gary
Don't be too quick. There are a lot of new products out.
I've seen a plumber using this one.
Note the trap portion is not corrugated.
Old 5/6/08, 2:03 PM
Harry E. McClard's Avatar
Harry E. McClard Harry E. McClard is offline
I've run across a bunch of those also. It looks like there is a little vertical offset and maybe that's why the flexible tailpiece is there?; can't see weir or vent in the picture though. The ones I have run across, I just make a mild-mannered note that mentions the flex and offset in case they ever decide to go go out and get a fancy chrome plated rigid one or whatever.
Old 5/6/08, 10:20 PM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
Isn't it wonderful, all the products they make to help you make a bad installation fit.
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Old 5/8/08, 9:19 PM
Vince Santos's Avatar
Vince Santos Vince Santos is offline
One or more sink drains use flexible drain pipe. This type of drain pipe is more likely to clog than smooth wall pipe. Recommend having a qualified plumber replace this pipe with standard plumbing components (smooth wall pipe) to prevent clogged drains.
Vince Santos
StepByStep Home Services LC
(734) 748-9584
Providing Home Inspection Services to Southeast Michigan
facebook
ITA Trained and Certified
