View Poll Results: Adequate water heater collision protection?
Yes 19 52.78%
No 17 47.22%
Voters: 36. You may not vote on this poll
Old 10/14/07, 8:35 PM
Joe Funderburk, CMI's Avatar
Default Adequate water heater collision protection?
Do you consider this to be adequate protection from collision impact? I'm seeing it more and more in new homes.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 10/14/07, 8:51 PM
Default Re: Adequate water heater collision protection?
Hi Joe, I guess it depends on how and what the wall is framed with but even bollards will tip over if hit hard enough.
Larry Kage, CMI
231 929 3525
Old 10/14/07, 8:53 PM
I didn't dismantel the wall, but I banged on it and it felt like 2x4 studs.
Theodore Roosevelt
Joe Funderburk, CMI
Old 10/14/07, 9:11 PM
If anchored adequately, I'd go for it.
The vent pipe on the watewr heater looks like it runs downhill.
Larry Kage, CMI
231 929 3525
Old 10/14/07, 9:14 PM
So you think a 2x4 (maybe even 3 of them in that wall), however anchored, will provide protection? Maybe from a lawn mower. Not an automobile in my view.
Theodore Roosevelt
Joe Funderburk, CMI
Old 10/14/07, 9:16 PM
Vent does run downhill. I called that out. Good eye. Also called out the foam in contact with the flue and the draft hood loose.
Theodore Roosevelt
Joe Funderburk, CMI
Old 10/14/07, 9:24 PM
Stephen W. Stanczyk's Avatar
Probably no different than the wall with the panel in it. Say the water heater was in the house on the other side of the back wall. Same 2x4 wall. Are you saying that isn't proper protection either? You hit a wall with your car, you have other problems also. Typical new construction is with the heater and water heater in a similar built up area at the back of the garage.
Stephen Stanczyk
Old 10/14/07, 9:25 PM
Plates anchored to the concrete adequately and above adequately..a sufficient number of studs angle bracketed adequately to the plates...then sure, I think it would be fine.
Larry Kage, CMI
231 929 3525
Old 10/14/07, 9:34 PM
The code requires protection of water heaters in garages. Not inside the living space. Note the location of the gas lines; 2 inches on the other side of the 2x4 wall.
Theodore Roosevelt
Joe Funderburk, CMI
Old 10/14/07, 10:26 PM
Bruce A. King's Avatar
Good question.....
From an inspectors view point, we can't say its wrong.
We can say it appears to be wrong.
I would report inadequate working space to access the gas valve based on the picture, the unit is installed with the wrong side facing out.
The front should have 30 inches of working space, the front is facing that crash wall.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 10/14/07, 11:49 PM
Dale Duffy's Avatar
I'd bet not a sole who worked on that shack had a valid SS Number.......
Old 10/14/07, 11:53 PM
CC Senior.
Theodore Roosevelt
Joe Funderburk, CMI
Old 10/15/07, 12:12 AM
Dale Duffy's Avatar
CC Senior.
This home is not E-Verified ..............
Old 10/15/07, 12:33 AM
Christopher Currins's Avatar
And probably not to familiar with hot water either.
Christopher Currins
Certified, Licensed
Old 10/15/07, 12:36 AM
Russel Ray's Avatar
Depends on whether or not there is a female driver in the household and parking her car in the garage.
Oooooooops.
Client wants a new water heater adirienzo General Inspection Discussion 47 7/14/10 2:03 PM
Venting an oil-fired water heater mh718 Inspecting HVAC Systems 3 11/16/06 9:36 AM
TPR & Combusiton Air thejnicki Plumbing Inspections 16 9/18/06 8:55 PM
