I am trying to determine the age of a water heater. It is a Rheem water heater and the serial number is 335 10002. Note there is a space between the numbers as shown. The home was built in 1966 but the heater appears to have been replaced. Every source I have checked shows to use the 1st four digits of the serial number but the serial on this unit is different than any I have seen on Rheem heaters.
Is anyone familiar with this numbering system? Robert Sole, CMI 407-637-7288 Florida license numbers HI 169 and MRSA 92 Serving the Orlando Florida area including Orange, Seminole, Northern Osceola and Southwestern Volusia Counties. RobertSole@REMinspections.com Check out my blog orlandohomeinspections.info/ REMinspections.com OrlandoHomeInspector.net |
Looks like no one has found the age yet.
You should be able to tell if its older than 10 years just by looking at the logo/labeling on it. Simply recommend replacement on these when older than 10 years. Client just called me and said they wish they had took my advice, their 10 year old water heater just started leaking. I don't defer many things to contractors, I simply make the decision as I'm being paid to do. If you can't make a decision in this business, the agents favorite driveby contractor will be available to say its ok and collect his $60 driveby fee from the agent. An agent told me once that that she tells buyer's to ignore everything in an inspection report where it appears the inspector had no true opinion since all reports she has seen over the years are basically soft and inconclusive. I told her that she would either love or hate mine depending on her loyalty to the buyer. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
If there is an ANSI number, you can at least narrow down to a 4 year period. For what it's worth.
2000 ? whats the ansi number?
"Be Proud of Your Home, Go With Pride!" 'Not just a Home Inspection, but an Education' Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties. |
The American National Standards Institute (ANSI) sets standards for safety, conformity and other things http://www.ansi.org.
They update standards every four years. If you have a date of 2000, then the unit was manufactured between 2000 and 2004. Regards, Bill |
You dont have a picture of that number, do you?
I appreciate the responses. I did not look for and ansi number. I carry some information I found a while back with me for these situations but with Rheem, is said that the third and fourth numbers were the serial number. This serial number was not the same as other Rheem water heaters.
I told the customer that my best guess was that the water heater was old enough that they had changed their serial number system and that he should think about replacing it. Robert Sole, CMI 407-637-7288 Florida license numbers HI 169 and MRSA 92 Serving the Orlando Florida area including Orange, Seminole, Northern Osceola and Southwestern Volusia Counties. RobertSole@REMinspections.com Check out my blog orlandohomeinspections.info/ REMinspections.com OrlandoHomeInspector.net |
| water heater age | bsprings | Plumbing Inspections | 17 | 6/14/10 10:37 PM |
| flammable vapor ignition resistant | dbaucum | General Inspection Discussion | 35 | 2/19/08 1:42 PM |
| Water Heater Dip Tube Failure | jacaron | Plumbing Inspections | 2 | 2/24/07 11:28 PM |
| Rheem gas tankless water heater | bking | Plumbing Inspections | 3 | 8/15/06 5:13 PM |
