I have an air admittance value in the crawl space with the top of the value 2" from the bottom of the floor insulation. Does anyone see an issue with that?
Thanks, Russell Truluck |
No. AAV's are OK in a crawlspace or even inside a sink cabinet.
If I see more than one AAV in a home, then there are issues. |
I've never heard of AAV's being allowed in a crawl space. Admittedly, I don't see many AAV's in CA (because they're not allowed by State Standards) but from what I know they're required to be near or above the flood level of the fixture(s) they serve.
It seems to me that an AAV in a crawl space is just asking for trouble. . . David - why would multiple AAV's be a problem? IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net Last edited by jpope; 6/4/08 at 8:48 PM.. |
If you had an AAV below the level of the trap, what would be the point. Gases are supposed to rise through the system.
In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
When I find one under the kitchen sink, I know they will be in the bathrooms and the laundry, and, indeed, they area. NACHI 2005 U.S. Member of the Year
But why would multiple AAV's be a problem?
They are not a perfect devices or without problems in the long term. Your AHJ and codes would determine what is allowed in your area. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
I find multiple AAV's in the rich areas with McMansions. The reason is because all those ugly vents sticking up through the roof make the roof ugly. So when one has 19 bathrooms and 37 sinks, one really doesn't want 37 doohickeys sticking up through the roof making the roof uglier than it already is. Fewer doohickeys sticking up through the roof also make it easier for our South-of-the-Border roofing labor to install the roof. That flashing around 37 doohickeys can be soooooooo troublesome. NACHI 2005 U.S. Member of the Year
The CPC does not recognize AAV's. As always, local jurisdictions vary. I've seen them in subdivisions as well as in manufactured homes - it usually depends on whether the area is incorporated within the county, having their own building standards. Unincorporated areas will usually be following State Codes.
In most homes (where I've seen AAV's), they've been installed in the attic. Manufactured homes will generally have them at each fixture (that's why I asked), but I can't recall ever seeing one in a crawlspace. . . IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
If construction is well planned ahead of time, and sewer stacks are considered into the plan, AAV's are not needed because multiple fixtures can be added into a single sewer stack. Normally I see a single AAV's in manufactured homes (at the kitchen sink) due to the distance from the bathroom to the kitchen. I hardly ever see AAV's in SF homes. |
I'm trying to learn something here. Thanks. NACHI 2005 U.S. Member of the Year
Use your head for something other than a hat rack.... |
| Emissivity Values from Fluke | mkyriacou | Thermal Imaging, Infrared Cameras & Energy Audits | 5 | 5/10/08 8:50 PM |
| Air admittance valves | rtruluck | Plumbing Inspections | 2 | 12/29/07 4:24 PM |
| Homeowners are going underwater as loans pass home values | jburkeson1 | Miscellaneous Discussion for Inspectors | 3 | 11/11/06 8:19 PM |
| Proper use of an air admittance valve? | cceccarelli | Plumbing Inspections | 5 | 5/12/06 6:16 PM |
