aharper1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Can a air admittance valve be under a sink? If it can, Can it be connected to 2 traps right on top of each other
I don't see a problem with it. But I await other comments.
The plumber did the same thing to my sink to stop the slow drain problem.
Kenneth Sitzes NACHI #04122492 Eagle Inspection of Illinois 618-830-8283 Waterloo, Illinois 62298 ghinspector@yahoo.com InterNACHI State of Illinois Continuing Education Administrator |
twasion is a non-member guest and is in no way affiliated with InterNACHI or its members.
This is okay where I use to plumb. What I have a problem with, which is not a problem in some parts of the country, is the Air Admittance valve is too low and should be above the flood rim of the sink. The reason for this is in case of stoppage water will not flow out the Air Admittance valve and they will.
jclark1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
I think if used as a fixture vent it needs to be a certain distance above the weir, not neccesarily above flood rim. If used as stack vent, they must be above the highest fixture's flood rim, can't be in a wall, etc.
If the AA valve wil prevent air from exiting the vent pipe, won't it also prevent waste from the sink from exiting?
| Air admittance valve usage | Jim Swell | Plumbing Inspections | 8 | 11/1/07 4:22 PM |
| TPR valve | acox | Plumbing Inspections | 19 | 5/27/07 1:36 PM |
| Air Admittance Valve Installation | jmichalski | Plumbing Inspections | 8 | 12/8/06 1:05 PM |
| Proper use of an air admittance valve? | cceccarelli | Plumbing Inspections | 5 | 5/12/06 7:16 PM |
