Old 9/22/08, 1:29 AM
jjones2's Avatar
jjones2 jjones2 is offline
Send a message via MSN to jjones2
Default Air Admittance Valve Help
Are air admittance valves allowed in the main drain pipe like this?
Home is only 5 yrs old. Kitchen has AAV installed correctly but this one for the tub just seems like a potential for sewer leakage in the event of a backup!
Thanks in advance for the help
John
All Tech Home Inspections
www.alltechinspect.com
Old 9/22/08, 2:57 AM
Gerry Pallotta's Avatar
Gerry Pallotta Gerry Pallotta is offline
Send a message via Yahoo to gpallotta
Default Re: Air Admittance Valve Help
John
It seems to be o.k. there, but here is some more info.
http://www.toolbase.org/pdf/techinv/aavs_techspec.pdf
Old 9/22/08, 7:29 AM
Russell J. Hensel's Avatar
Russell J. Hensel Russell J. Hensel is online now
Hope this helps
Old 9/22/08, 8:20 AM
Hi John
Here is the actual code.
3114.4 Location
Individual and branch air admittance valves shall be located a minimum of 4 inches (102 mm) above the horizontal branch drain or fixture drain being vented. Stack-type air admittance valves shall be located a minimum of 6 inches (152 mm) above the flood level rim of the highest fixture being vented. The air admittance valve shall be located within the maximum developed length permitted for the vent. The air admittance valve shall be installed a minimum of 6 inches (152 mm) above insulation materials installed in attics.
http://www.studor.com/codes.htm
Old 9/22/08, 8:49 AM
jjones2's Avatar
Thanks for the help guys, I called it an untypical installation and review by a Qualified Plumber is recommended.
Thanks again
John
Air Admittance valve? 2 traps aharper1 Plumbing Inspections 5 9/24/06 7:42 PM
Proper use of an air admittance valve? cceccarelli Plumbing Inspections 5 5/12/06 6:16 PM
