Old 12/8/06, 11:29 AM
jmichalski's Avatar
jmichalski jmichalski is offline
Please Note: jmichalski is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Air Admittance Valve Installation
OK - Since there was a recent discussion of AAVs, but I am not 100% clear on proper use/installation, I want to double check...
This AAV was on a kitchen sink over a slab (an addition).
The vent stack was at the rear of the home, this kitchen is located over an old garage to the side and enters the soil line just before it exits the home to the street side. (similar to another I saw previously and referred for review since local code may not allow the use of the AAV)
Is this the proper installation? As I understand the AAV operation, it is self venting, activating with negative pressure, so it does not need to be tied into the vent stack - correct?
As you can see from the picture some plumbing work is needed anyway , but I would like to know for my own education about this device.
Any and all advice is welcome (I am writing the report now). I will include a mention to verify with AHJ that this device is allowed, but comments regarding the proper installtion would be helpful -thanks!
Old 12/8/06, 11:33 AM
Default Re: Air Admittance Valve Installation
This is a proper installation. Yours looks ok going by this.
Abraham Lincoln
Old 12/8/06, 11:37 AM
Jeffrey R. Pope's Avatar
The AAV may be okay, but the S-trap is no good. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 12/8/06, 11:41 AM
jmichalski's Avatar
Originally Posted by jpope
The AAV may be okay, but the S-trap is wrong. . .
Yeah (not to mention the bucket!) - there is also galvanized supply lines in the basement to the old bathroom, and what I can only guess is a homeowner attempt at rigging up the sump pump. Enough for a plumber to do, but I wanted to know if I was on solid ground in not recommending venting for the AAV (especially since I KNOW a plumber will be there and have his 2 cents! )
Old 12/8/06, 11:42 AM
jmichalski's Avatar
Blaine, that is very small on my screen - is it a file you can email to me, or post in larger or attached format? Thanks!
Joe
joem@sherlockhomesinspection.net
Old 12/8/06, 11:47 AM
An AAV is a vent system, so it is its own "vent stack." The only difference is, that it doesn't go through the roof.
The AAV should be as high as possible, and accessible.
Without looking at the balance of the drain line system in your picture, the position of the AAV looks good. . .
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 12/8/06, 12:08 PM
jmichalski's Avatar
Thank you, Jeff. That is what I understood, but I wanted to double check with some of the higher minds here (especially you!!)
Old 12/8/06, 12:51 PM
Bruce M. Graham, III's Avatar
Bruce M. Graham, III Bruce M. Graham, III is offline
That's in much better shape than this one.
Happy Inspecting
Bungalows to Mansions
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 12/8/06, 1:05 PM
jclark1's Avatar
jclark1 jclark1 is offline
Please Note: jclark1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
An AAV used as an individual fixture vent should be at least 4" above the fixture's drain. An AAV used as a stack vent should be at least 6" above highest fixture's flood rim.
Air admittance valve usage Jim Swell Plumbing Inspections 8 11/1/07 4:22 PM
Air Admittance valve? 2 traps aharper1 Plumbing Inspections 5 9/24/06 8:42 PM
Proper use of an air admittance valve? cceccarelli Plumbing Inspections 5 5/12/06 7:16 PM
