Exterior AAV I believe was on the sump discharge. Why? Anyone ever seen an install like this? Comments and/or narratives welcome.
Thanks in advance. |
| Need a home inspection in Alabama? Check out InterNACHI's listing of Alabama certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Are you sure?
One thing it will be useless in another snow or two covered up. I would comment to evaluated and repair by a plumber short and sweet. Wayne Wilson East TN Home Inspections LLC Knoxville, Oak Ridge, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-1490 http://site.myhomeinspection.net |
I see sumps all the time, and I can honestly say I have never seen a sump discharge quite like that. Are you positive that is what it is? Are you saying the sump is actually discharging through that valve? AAV's don't operate that way. One way the wrong way, and no way it could handle the flow. Must be a custom valve made for that purpose. Reminds me of a sink air gap. Very interesting.
Not to mention freezing up/ice with that small outlet.
Not 100%, but pretty sure. Nothing short of digging it up or scoping it with a video snake, it was right in line with the basment sump line which exited the basement wall.
No it wasn't discharging out the vent. The line was about 2 or 3 ft below this, which I'm assuming there's a tee or wye with a riser and then this vent. Where it discharged to, I have no clue.
If it has a long discharge distance, they may have installed it sort of as a "vacume break" to help prevent drainback. Don't see thouogh how this would work any batter than a check valve in the vertical section of discharge piping. Did it have a check valve installed? Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
That could be your answer.
If you ever find out for sure, let us know. Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
It would have been easier to install a check valve lol
And probably about the same $$. Heck, they both have about the same lifespan to boot, the check valve prolly longer due to not being exposed to the elements such as snow/ice!
| TPRV valve | kblanchard | Plumbing Inspections | 16 | 1/19/12 9:22 PM |
| Sump Discharge - Who does this? | joverholser | Plumbing Inspections | 6 | 10/1/11 7:03 AM |
| sump pump discharge | vwood | Plumbing Inspections | 10 | 6/18/07 10:59 PM |
