Old 5/3/07, 2:02 PM
Eric Hyde Eric Hyde is offline
Default Air Admittance Valves
I've been running into these plumbing vent valves a lot recently, the kind that do not require roof penetration, and I'm curious to know from some more seasoned inspectors what they think of them. Are these kind of venting valves okay under a kitchen sink or in the attic?
Here's a good picture of them.
Thanks.
Old 5/3/07, 5:43 PM
Jeffrey R. Pope's Avatar
Default Re: Air Admittance Valves
They are a mechanical valve and, therefore, subject to failure. Check your local codes to see if they are allowed. IRC says they're okay, UPC does not recognize them.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 5/3/07, 8:04 PM
Jeff, you bring up a good point here.
Maine does not allow Mechanical vents as of last year. How would we address the fact of it's existance in dwellings before the Code change?
Since we are not Code Officers, how does it get addressed in the report?
Could we look at it as a Safety issue?
Point out that it is no longer accepted by the Building Plumbing Code and needs to be upgraded?
What are your thoughts on that subject?
Thanks
Marcel
Old 5/3/07, 8:28 PM
CA does not allow them, although some local jurisdictions do. Here is one of my standards when I see these. You might be able to modify it for your state.
The drain-waste-vent system (DWV) employs a mechanical vent, also known as an air-admittance valve or AAV. This application may have been approved by this local jurisdiction, however, you should be aware that this type of system is not recognized by California Building Officials as an approved vent system. Although they may function as intended, AAV's are a mechanical component, and as such, they are subject to failure over time. Failure of these mechanical vents may allow sewer gases to escape into the attic or living space, which would result in potentially hazardous and unhealthy conditions. If, at any time, you notice an odor consistent with waste or sewage, you should immediately contact a qualified plumber to evaluate the AAV's.
I think it's a bit of a stretch to call it as a "safety" issue, unless they are not functioning.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 5/3/07, 8:43 PM
Thanks Jeff, that was a lot of help.
Marcel
Old 5/3/07, 9:18 PM
Charley L. Bottger's Avatar
Just ran into my first AAV in an attic this week on a 3 inch vent set me back on my heels for a moment used to seeing them on sinks not in the attics here; darn Plumbers connot find a good one any more all they want to do is take short cuts. Maybe we should all turn the clocks back and start using outhouses again????
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 5/3/07, 10:42 PM
James H. Bushart's Avatar
It may be worthy to add the smell (rotten eggs) of hydrogen sulfide, or "sewer gas" to your list of odors.
One of the problems with hydrogen sulfide is that, after a few whiffs, it will deaden the olfactory nerves (sense of smell) and while still being in high concentrations, it becomes odorless.
Hydrogen sulfide effects are also cumulative and, repeated exposures even to small levels, have been known to cause neurological damage.
The nose not always knows.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas.
Old 5/3/07, 10:57 PM
I might just do that. Thanks James. . .
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 5/4/07, 10:08 PM
homebild homebild is offline
It is not unusual that you should be seeing air admittance valves on plumbing vents in Oklahoma since Oklahoma has adopted the International Plumbing Code and the plumbing provisions of the International Residential Code statewide.
Both the IPC and IRC plumbing provisions allow air admittance valves on all vents except for pneumatic sewage ejectors, except on the required one 3" vent that penetrates the roof as a main vent, and where local codes restrict or forbid AAV use.
AAVs are also allowed in Maine jurisdictions and elsewhere that have adopted the IPC and IRC plumbing provisions.
To see which ICC Codes, if any your state or municipal jurisidction have adopted, click the state on the ICC map link here:
http://www.iccsafe.org/government/adoption.html
Old 5/5/07, 7:23 PM
Brian C. Hoagland Brian C. Hoagland is offline
How much you wanna bet that valve was installed post contruction after some moron completed the roof without the penetration? May not be the plumbers fault!
</IMG>
Old 5/6/07, 10:10 AM
</IMG>
I will bet anything you have to loose.
The home was a 100 years in age and had been gutted in 1995 with a new bathroom installed in the original part of the home the plumber just did not want to cut a hole in the roof. Would of been very easy in that location of the roof that is why they started making hole saws and sawzalls?????
</IMG>
NACHI Member
State License # 130
Old 5/6/07, 2:12 PM
Back to Codes
StateIPCIRCUPCNSPC
Approval Status
as of 8/ 2006
AlabamaXX
Approved
AlaskaX
Not approved
ArizonaX
Approved
ArkansasX
Approved
CaliforniaX
Partial approval
ColoradoXX
Approved
ConnecticutX
Approved
DelawareXX
Approved
D.C.XX
Approved
FloridaX
Approved
GeorgiaXX
Approved
HawaiiX
Not approved
IdahoX
Not approved
Illinois
Not approved
IndianaXX
Approved
IowaX
Not approved
KansasXX
Partial approval
Kentucky
Not approved
Louisiana
Not approved
MaineXX
Partial approval
MarylandX
Approved appendix "E"
2005 edition
Massachusetts
Not approved
MichiganXX
Approved
Minnesota
Not Approved
MississippiXX
Approved
MissouriX
Partial approval
MontanaX
Not approved
NebraskaXX
Not approved
NevadaX
Partial approval
New HampshireX
Approved
New JerseyX
2005 edition
New MexicoX
Not approved
New YorkXX
Approved except NYC
North CarolinaXX
Approved
North DakotaX
Not approved
OhioX
Approved
OklahomaX
Approved
OregonX
Not approved
PennsylvaniaXX
Approved except
Philadelphia
Rhode IslandXX
Approved
South CarolinaXX
Approved
South DakotaX
Partial approval
TennesseeX
Approved
TexasXXX
Partial approval
UtahXX
Approved
VermontX
Approved
VirginiaXX
Approved
WashingtonX
Partial approval
West VirginiaXX
Approved
WinconsinX
Approved
WyomingXX
Not approved
IPC=Internatinal Plumbing Code IRC=International Residential CodeUPC=Uniform Plumbing Code NSPC=National Standard Plumbing Code
<DIV class=printhide id=u52 style="Z-INDEX: 1000; LEFT: 0px; POSITION: absolute; TOP: 0px">
Old 5/7/07, 10:13 PM
Right, Marcel
AAVs are permitted in Maine jurisdictions but ONLY where they are approved by Code..
Both Studor (only one such manufacturer of AAVs) and the ICC Plumbing Codes acknowledge this...
Whether or not AAVs can be used in Maine depends entirely on the municipality involved.
Old 5/7/07, 10:35 PM
Peter C. Russell's Avatar
AAVs IMO are great for older homes, but do have their draw backs due to failure, but if that's the only way to vent a sink what are you going to do?
I point them out and educate my client on their limitations and put that into the report. I see nothing wrong with them, I have one in my house.
Need Title 24 (CA) reference for TPR valves jhugenroth Plumbing Inspections 12 8/31/09 3:12 PM
Does anyone know anything about corrugated stainless steel tubing (CSST)? gromicko Structural Inspections 5 9/28/07 7:24 PM
Air admittance valves everywhere apfaff Plumbing Inspections 13 4/16/07 10:17 AM
Bathroom Shut-off Valves - Mineral deposits - Do you note them as leaking in reports? jwatts1 Plumbing Inspections 8 7/29/06 12:50 PM
Shutoff Valves?? tpriddy Plumbing Inspections 9 2/23/06 5:57 PM
