Old 11/1/09, 7:37 PM
Default Air hammer Arrestors
Why would they install one of this with a well system for domestic with 40# pressure?
MINI-TROL®
Water Hammer Arrestor
Mini-Trol® shock suppressors are the perfect solution for individual fixtures. The compact design can fit anywhere a washing machine, dishwasher or toilet is installed. The permanently sealed diaphragm will not waterlog like tube-type air chambers.
Features
• Non-Metallic Internals
• Sealed Air Charge
• Easy Installation
Download Brochure (pdf)
Find an InterNACHI certified Utah Home Inspector (and anywhere else in North America)
Old 11/1/09, 8:17 PM
Terry Clayton Terry Clayton is offline
Default Re: Air hammer Arrestors
Some people have to have the latest and greatest and they jump befor they look. I t also may have been for future considerations.
Old 11/1/09, 8:26 PM
Thanks Terry, was curious, because this was the only set in the house and installed in the Master Bedroom Bath under the lavatory on the second floor or actually the third floor if you count the basement where the pressure tank is.
Just did not make any sense and was the first time I had seen this type.
House was built in 92 in Northern Maine. My Daughters new house.
Thanks for the reply.
Old 11/1/09, 8:51 PM
Wayne B. Wilson's Avatar
could be they had a water logging problem Marcel with the pump short cycling
Old 11/1/09, 9:02 PM
Thanks Wayne, and here was the configuration in the basement, appears to be showing a storage take for well water, not sure, I just recommended that they hire a water purification contractor to evaluate the whole set up and provide instructions on how to maintain this whole thing.
I tested the pressure outside and showed 40#'s just like inside, but did not check the third floor.
Old 11/1/09, 9:16 PM
Jeffrey R. Jonas's Avatar
Marcel,
After seeing your post (#5), I believe your post (#1) is a result of an experienced salesman. Can you say..."add-on sales"?
Jeff
Old 11/1/09, 9:18 PM
I wonder why 2 bladder tanks Marcel
Old 11/1/09, 9:37 PM
Don't know Wayne, that is what I am trying to figure out, I am not the best plumber, technical wise, here. That is for sure. Had me baffled at the installation when I was there.
I think, recommending a plumber might be prudent, and like Jeff said above, it might have been a good salesman.
I couldn't figure out if that big tank is for storage or for treated storage water.
This was the third owner of the house and this was all there when he bought it.
Thanks for the help.
I think Jeff might be on the right track. Only a good qualified plumber would know I guess.
Old 11/1/09, 9:50 PM
I am sure it is only for storage Marcel, it doesn't appear to be in line with the softener only with the smaller bladder
Old 11/1/09, 9:58 PM
That is the way I saw it to Wayne, but there is one valve that is shut and made me wonder why also.
I hate it when I am boggled like that due to my ignorance in plumbing of the sort.
Although, I will recommend a plumber to evaluate the installation and correct a couple of S-traps that I found, the house was great.
Well, it should be for $250,000 in Caribou, Maine.
Damn, it's to only place you can go in Maine where you can drive for 114 miles and the only thing you see on the GPS is Interstate 95.
Old 11/1/09, 9:59 PM
Sounds like a great place. Marcel good luck and let us know the outcome.
Old 11/1/09, 10:12 PM
Michael Larson's Avatar
I only see one. Wayne.
Michael Larson
Hudson, WI
[/I]
Old 11/1/09, 10:20 PM
The first tank on the left is a retention/storage tank to remove sediment and white drum next to it has a chemical injection pump to treat the water for some condition. (could be acidic water or other conditions making the water unpalatable or corrosive. The black tank is a salt drum for the water softener next to it.
Marcel,
Your advice to hire a water professional is appropriate because your daughter needs to know what condition is being treated and she needs to learn how to service the system to keep it working.
She may have to blow off the sediment periodically and she also needs to know what condition is being treated and how to service that portion and add chemical.
Michael Larson
Hudson, WI
[/I]
Old 11/2/09, 6:58 AM
I agree Mike and thanks
Old 11/2/09, 7:01 AM
I was wonder if the large one was a sand filter Micheal but they do make a bladder tank also.
Cutler Hammer Breaker gwilcox Electrical Inspections 2 10/7/09 10:29 PM
Double Taps in Cutler Hammer Panel bhartley Electrical Inspections 38 7/1/09 5:42 AM
Cutler Hammer panel with Square D breakers bhartley Electrical Inspections 3 11/25/08 9:48 PM
The Hammer King bdoles2 Miscellaneous Discussion for Inspectors 1 11/2/07 4:48 PM
Sq D 200 amp panel with Cutler Hammer Breaker lfoster Electrical Inspections 7 6/28/07 10:06 PM
