Old 10/6/11, 9:07 PM
Joseph Tribuzio's Avatar
Joseph Tribuzio Joseph Tribuzio is offline
Question Aluminum pipe used for tprv
OK, i feel that the aluminum pipe is not an adequate material for a TPRV discharge, my reasoning is that it is not supposed to handle high pressure and high temps, and it bends super easy therefore making it less resistant to pressure. '
But how do i convey this, is there something on this i can reference?
Trying to figure how to write this up.
Joseph Tribuzio 708 453 8447
Tribuzio Home Inspection Services
CHICAGOLAND, ILLINOIS
www.thishomeinspector.com
ID# NACHI07062507
IL Lic#450.003128
Radon lic# RNIT2008216
Home Inspector Pro Software
HIP Web Hosting
Need a home inspection in Michigan? Check out InterNACHI's listing of Michigan certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/6/11, 9:13 PM
Stephen W. Stanczyk's Avatar
Default Re: Aluminum pipe used for tprv
Allowable materials for TPR drain line are the same as for water distribution lines.
Galvanized steel, hard drawn copper, CPVC and most jurisdictions also allow PEX although some don't.
Stephen Stanczyk
Old 10/6/11, 9:21 PM
From the 2006 IRC.
- P2803.6.1 Requirements for discharge pipe. The discharge piping serving a pressure-relief valve, temperature-relief valve or combination valve shall:
- - 13. Be constructed of those materials listed in Section P2904.5 or materials tested, rated and approved for such use in accordance with ASME A112.4.1.
TABLE P2904.5
WATER DISTRIBUTION PIPE
MATERIAL ------------------------------------------------ STANDARD
Brass pipe ------------------------------------------------ ASTM B 43
Chlorinated polyvinyl chloride (CPVC) plastic pipe and tubing - ASTM D 2846; ASTM F 441; ASTM F 442; CSA B137.6
Copper or copper-alloy pipe -------------------------------- ASTM B 42; ASTM B 302
Copper or copper-alloy tubing (Type K, WK, L, WL, M or WM) -- ASTM B 75; ASTM B 88; ASTM B 251; ASTM B 447
Cross-linked polyethylene (PEX) plastic tubing ---------------- ASTM F 877; CSA B137.5
Cross-linked polyethylene/aluminum/cross-linked polyethylene (PEX-AL-PEX) pipe - ASTM F 1281; CSACAN/CSA-B137.10
Cross-linked polyethylene/aluminum/high-density polyethylene (PEX-AL-HDPE) - ASTM F 1986
Galvanized steel pipe ---------------------------------------- ASTM A 53
Polybutylene (PB) plastic pipe and tubing --------------------- ASTM D 3309; CSA CAN3-B137.8
Polyethylene/aluminum/polyethylene (PE-AL-PE) composite pipe - ASTM F 1282
Polypropylene (PP) plastic pipe or tubing ----------------------- ASTM F 2389; CSA B137.11
Stainless steel (Type 304/304L) pipe -------------------------- ASTM A 312; ASTM A 778
Stainless steel (Type 316/316L) pipe -------------------------- ASTM A 312; ASTM A 778
Larry Kage, CMI
231 929 3525
Old 10/6/11, 9:44 PM
ahh good resources thanks guys
ID# NACHI07062507
IL Lic#450.003128
HIP Web Hosting
Old 10/6/11, 10:11 PM
Christopher Currins's Avatar
Illinois Plumbing Code:
3) Any piping used for discharge from the relief valve shall be of metallic material and conform with the requirements of Appendix A, Table A (Approved Materials for Water Distribution Pipe) for potable water piping and shall drain continuously downward to the outlet.
No aluminum listed here.
Christopher Currins
Certified, Licensed
Old 10/6/11, 11:16 PM
Joe Funderburk, CMI's Avatar
Don't think I've ever seen an aluminum pipe. Interesting.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Pellet stove help chellickson General Inspection Discussion 23 8/19/10 1:23 AM
Is this allowed? belliott Plumbing Inspections 4 7/15/09 6:40 PM
Help - Polybutylene Pipes Rick G Plumbing Inspections 39 2/12/09 8:16 AM
Identify ABS defective pipe mcyr Plumbing Inspections 6 1/29/09 6:39 PM
Nice Report on AL Wire Terminations - Enjoy pabernathy Electrical Inspections 0 7/2/07 12:35 PM
