rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
WH on 2nd floor.
TRP drain terminates above floor drain in pic 2. In storage room in 1/2 bath downstairs. |
hhhhhmmmmmmmmmmmmmmmmm
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Home Inspectors, Inc. Scottsdale Home Inspectors, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Because with the pressure from a TPR opening up and a grate on the Flr Drn, well Water Water everywhere.
Looks okay to me too. In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
I guess my biggest concern is that they wouldn't know (couldn't see) if it was discharging. Also, don't know if it makes a difference but there was no grate on the upstaird Flr Drain. |
Bold is what concerns me
I see these type of PTR valve installations in Condos.
I simply explain to my clients, why I like to see the PTR termination and note that the PTR valve can not be monitored. Definitely make a note about the elbows in the PTR extension pipes. |
Rick yours is not as cute as mine this one terminated within the shower stall just in case one needed an extra boost of good hot water
9. Discharge through a visible air gap (atmosphere) in the same room as the water heater. 14. Discharge to a termination point that is readily observable by occupants because discharge indicates that something is wrong. I would love it if that were the case here, but most, if not all, manufacturers approve of 4-6 90° angles. I guess that's "as straight as possible." Rarely in new construction do I see the pipe terminating in the same room as the water heater. They now route them outside, which I don't like because of #14. Nonetheless, every AHJ in every city here approves of them being terminated outside. NACHI 2005 U.S. Member of the Year
Typical condo weirdness...
At one of my recent condo inspections in a well known large chicago building ( that looks like a setr of corn cobbs), I found the small tank water heaters TPR discharge was a copper flex ( kinked too) that was routed up to disharge into the small ss kitchen sink through what looked like the soap dispenser spigot. Of course i called it out as extremely dangerous and amateurish installation. It appears that every unit in this massive building that was converted was done this way. I alerted the city plumbing inspectors office. They were pretty shocked and glad i called. Joseph Tribuzio 708 453 8447 Tribuzio Home Inspection Services CHICAGOLAND, ILLINOIS www.thishomeinspector.com ID# NACHI07062507 IL Lic#450.003128 Radon lic# RNIT2008216 Home Inspector Pro Software HIP Web Hosting |
Christopher Currins Certified, Licensed Proudly serving the Illinois Metro-East Illinois Home Inspector Top 5 Tasks for January |
Payable to: ADAIR INSPECTION 1733 GOLIAD DRIVE GARLAND, TX 75042-4238 ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
